Why can’t we specify which device screen types can access a dashboard? I don’t necessarily want to use media queries and conditional cards because I want the views to be different, not different sizes of the same thing.
2 points are here - and it breaks a rule “1 WTH = 1 point”:
It should be solved by mediaquery-based rules (these “mobile”, “tablet”, “desktop” are abstract): there should be a possibility to define these rules for every view (on “enable” or “disable” basis).
This is a different point. Worth a separate feature request.
Actually using Sections dashboard it is already possible. Each individual section can be configured to be visible for certain screen size:
I tried checking my tablet and desktop, but the sections aren’t visible on my desktop in the Arc or Safari browsers (after I cleared my browser cache). I disabled all those conditions and the sections still aren’t showing back up.
Yes, but:
- Sometimes it is needed to have mediaquery-based rules for a whole view, not a section.
- Sometimes “section view” is not what you need.
- May be, not sure: not all possible mediaqueries are supported: I see a generated code with “max/min width” but sometimes some other conditions are needed (like “touchscreen or not”). I have not tested it myself - so just a speculation.
