Why do custom Assist responses take so long to process?
I have 2 HA VPEs in 2 different rooms running the same firmware version (25.4.0 (ESPHome 2025.3.3)) and using exactly the same Assist pipeline. I have them each running a version of pretty much the same automation at bedtime for our boys. One, however, simply responds “done” and the other I have included a custom response in the automation.
The automation with the standard response responds almost instantly. The automation with the custom response takes 30s for Assist to respond. Is this to be expected with custom responses or is there a way to get the same speed of response as standard.
Originally, I had a list of random Marvel-based custom responses, but changed it to a single response to see if that made a difference - it didn’t.
Here are examples of both Assist debug logs, standard first:
custom response, which you can see takes 30s to process.
Here’s the custom response automation:
alias: Bedtime for XXXX
description: ""
triggers:
  - trigger: conversation
    command:
      - it's bedtime
      - goodnight
      - It is bedtime
  - trigger: state
    entity_id:
      - input_boolean.we_are_in_bed
    to: "on"
conditions: []
actions:
  - choose:
      - conditions:
          - condition: trigger
            id:
              - Voice
          - condition: state
            entity_id: assist_satellite.jarvis_xxxx_assist_satellite
            state: processing
        sequence:
          - alias: Respond with a Marvel goodnight.
            set_conversation_response: >-
              Dream big like Tony Stark, and maybe you’ll wake up with genius
              ideas for your own Iron Man suit!
          - wait_for_trigger:
              - trigger: state
                entity_id:
                  - assist_satellite.jarvis_xxxx_assist_satellite
                to: idle
            timeout:
              hours: 0
              minutes: 0
              seconds: 30
              milliseconds: 0
          - action: media_player.volume_set
              entity_id: media_player.jarvis_xxxx_media_player
              volume_level: 0.25
          - parallel:
              - action: music_assistant.play_media
                  entity_id:
                    - media_player.jarvis_xxxx_media_player_2
                  media_id: audible://audiobook/B017V677I8
                alias: Read an  audiobook on JARVIS media player
              - action: input_boolean.turn_off
                  entity_id: input_boolean.xxxx_light_toggle
                data: {}
      - conditions:
            id:
              - Stop play
        sequence:
          - action: media_player.media_stop
            metadata: {}
            data: {}
              entity_id: media_player.jarvis_xxxx_media_player_2
mode: single
It might have something to with the 30 second wait timeout you have and the following:
https://www.home-assistant.io/docs/scripts/#respond-to-a-conversation
Try it with the announce action instead:
description: ""
triggers:
    command:
      - it's bedtime
      - goodnight
      - It is bedtime
  - trigger: state
    entity_id:
    to: "on"
conditions: []
actions:
  - choose:
      - conditions:
            id:
              - Voice
          - condition: state
            state: processing
        sequence:
          - alias: Silence normal response.
            set_conversation_response: ''
            action: assist_satellite.announce
              message: |
              preannounce: false
          - wait_for_trigger:
              - trigger: state
                entity_id:
                to: idle
            timeout:
              hours: 0
              minutes: 0
              seconds: 30
              milliseconds: 0
              volume_level: 0.25
          - parallel:
                  entity_id:
                data: {}
      - conditions:
            id:
              - Stop play
        sequence:
            metadata: {}
            data: {}
mode: single
The wait was my attempt at preventing the response from crashing the audiobook playing. ie wait until Assist has stopped responding before playing the audiobook, but now that you mention it, yes that timeout might account for the 30s response.
I’ll try it with your suggested change and see what happens, thanks.
