broesie
(Ryoen Deprouw)
March 6, 2017, 4:27pm
1
I got errors of Philips Hue in my logs, however I don’t use it…
Why do I still get those errors?
Error in the log:
17-03-06 03:17:02 WARNING (Thread-12) [netdisco.philips_hue_nupnp] Could not query server https://www.meethue.com/api/nupnp: HTTPSConnectionPool(host='www.meethue.com', port=443): Read timed out. (read timeout=5)
Mike_D
(Mike D.)
March 6, 2017, 4:32pm
2
Do you have a Phillips Hue Hub? The error makes it appear as though discovery is finding one.
broesie
(Ryoen Deprouw)
March 6, 2017, 4:34pm
3
Nope, nothing of philips hue installed…
Anything like a zigbee hat or stick?
broesie
(Ryoen Deprouw)
March 6, 2017, 7:14pm
5
I only using an aeotec z wave stick and a few fibaro dimmer modules, no philips hue…
Well then I don’t have any more ideas.
chrofs
March 7, 2017, 7:10pm
7
I have the same problem. not using hue
camfrout
(Camfrout)
March 8, 2017, 10:19pm
8
Same here. No hue but the error in the logs.
Bieniu
(Maciek)
March 10, 2017, 8:31am
9
I have the same warnings and I don’t use hue.
sebk-666
(Sebastian)
March 10, 2017, 10:02am
10
I’m using Hue and I see the same errors.
When I retrieve the URL manually, I get my Hue bridge IP as response:
# curl https://www.meethue.com/api/nupnp
[{"id":"00xxxxxxxxxxxx46","internalipaddress":"192.168.xx.yy"}]
So my guess is, that this is used by the discovery component to determine if there’s a Hue bridge and what IP it has.
I’m not sure what caused the error. Probably some congestion on the Philips side (meethue.com ) that prevented a timely response from the API.
From what I read in the documentation , a simple:
discovery:
ignore:
- hue
should get rid of the errors (preventing any future auto-discovery of a Hue bridge).
Maybe it’s philips_hue
- the docs are not clear on that.
Sebastian
EDIT: it seems to be philips_hue
- using only hue
fails the config check.
I recently installed pihole. To my surprise my pi (running only pihole and Homeassistant) is querying www.meethue.com every 5 minutes even though I am fully sure I don’t use hue and don’t use the emulated hue…
I think this is a bug.
