Turbo180
(Turbo180)
1
Why do I get this error message with this template?
hausverbrauch_actual:
friendly_name: "Hausverbrauch (aktuell)"
unique_id: Hausverbrauch_actual
unit_of_measurement: 'W'
device_class: power
value_template: '{{ (states("sensor.inverter_active_power") |float) - (states("sensor.power_meter_active_power") |float) }}'
EdwardTFN
(Edward Firmo)
2
Are you sure unique_id
is supported by the old format of template sensors? And are you sure unique_id
supports upper case?
Try this instead:
template:
- sensor:
- name: Hausverbrauch (aktuell)
unique_id: hausverbrauch_actual
device_class: power
availability: '{{ is_number(states("sensor.inverter_active_power")) and is_number(states("sensor.power_meter_active_power"))}}'
state: '{{ (states("sensor.inverter_active_power") |float) - (states("sensor.power_meter_active_power") |float) }}'
And do you get any error when you reload the template entities configuration or when you do a config check in Developer Tools?
Turbo180
(Turbo180)
3
I forgot to enter template and sensor in the yaml.
Thank you very much.
