Why do some of my Zigbee contact sensors have two "opening" attributes?
I brought several lots of Zigbee contact sensors and installed them using ZHA and the official HA blue Zigbee USB dongle.
The devices were basic white label rebrands. Some of them have two attributes labelled as “opening”, or they have “Opening” and “Opening 2”.
The first one does exactly what you would expect, it’s just a regular Open\close binary state that triggers when the sensor contact is broken and records in the history tab.
The second is always closed, even when the contact is broken, and it has nothing in the history. I’m not able to find any evidence that it does anything in HA.
I know that people get a little funny about white label sensors, but there doesn’t seem to be much of any use in identifying it any further.
TS0203
by _TZ3000_26fmupbb
Can anyone shed any light on this?
Had exactly the same issue . I simply ignore opening_2 . Not much help I know - but they seem to work just fine .
I’ve been ignoring it, too. But I was wondering if there was some cool feature that I was missing out on.
One of the random sensors that I brought had a built in light sensor that wasn’t mentioned on the box, others have other cool features.
Sometimes a sensor can go both ways meaning that the it can detect a magnet on each side.
This makes it possible to have it detct both the door being in the closed and open position with the same sensor.
l’ve just checked that and it looks like mine will only detect on both sides if you flip the magnet over, so it’s probably just one sensor being pushed or pulled rather than two sensors.
Good idea anyway.
Maybe this: ZHA - TS0203 & TS0202 have extra sensor entities created · Issue #106075 · home-assistant/core · GitHub
(Tamper sensor)
Does anyone know if ZHA ever plans on implementing tamper sensors?
Or is just the TUYA tamper sensors that are broken?
At this point Zigbee2MQTT is my only option for a lot of things
What exactly is wrong with the tuya tamper sensors? There aren’t any recent open issues that I’m aware of.
For ZHA they aren’t recognized and don’t work.
The links elzorro submitted show that.
The tuya sensors I have create two “opening” sensors. Only 1 tracks if the door is open/closed, the other never changes. It is always marked “closed”.
It seems that this may be the misidentified and not properly working tamper sensor.
