Why does changing board type to D1 mini from esp_1m hose up wifi connection?
Swear I could change this before but…now…
If I change…
Esp8266:
board: (to) d1 mini (from) esp_1m
I get…
INFO ESPHome 2024.5.3
INFO Reading configuration /config/esphome/esphome-web-20e73b.yaml…
INFO Detected timezone ‘America/Phoenix’
INFO Starting log output from 192.168.0.72 using esphome API
WARNING Can’t connect to ESPHome API for esphome-web-20e73b @ 192.168.0.72: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address=‘192.168.0.72’, port=6053))]: [Errno 113] Connect call failed (‘192.168.0.72’, 6053) (SocketAPIError)
INFO Trying to connect to esphome-web-20e73b @ 192.168.0.72 in the background
This is after trying to add static IP config. I do have Pi Hole but… I’ve added the hostname to DNS table.
When using dashboard to create add a new D1 mini, it defaults now to this esp_1m. It works but…all the others are set to d1 mini and I’m using d1 minis. Not a huge deal. Just a bit frustrated as to why this hoses up the config…lol.
