nappyjim
(Jim)
September 9, 2024, 1:10am
1
See picture below. i type in ‘rainfall sensor’. The item with friendly name ‘rainfall sensor’ comes up near the bottom of the “results”
koying
(Chris B)
September 9, 2024, 7:04am
2
Likely because “rainfall sensor” actually means “rainfall or sensor”.
aceindy
(Aceindy)
September 9, 2024, 7:23am
3
And you can verify that by typing
binary_sensor.rainfall
nappyjim
(Jim)
September 9, 2024, 11:53am
4
Was it always like that? I could have sworn in past i could put in friendly names and the one i named that would be first. Is there anyway to switch search results to friendly name?
I’ve seen topics similar to this in the past, but I could only find this issue which has apparently been fixed.
opened 12:42PM - 08 Oct 23 UTC
closed 07:50AM - 10 Aug 24 UTC
bug
### Describe the bug
I am no longer able to add events:state node for specific … entities. The list no longer filters based on what I type and I'm unable to type in the full entity name and have it appear in the list.
### To Reproduce
1. Add Event:State Node
2. In the entity field, select an entity (try to pick one not displayed in the drop down).
3. The list doesn't filter or move to the typed in entry and you are unable to enter the value manually as the list will select some arbitrary value.
### Expected behavior
I expect the entity list to filter down to the entities that match what I've typed in the field or, at the very least, I should be able to type in the full entity name and have it work.
### Screenshots
![image](https://github.com/zachowj/node-red-contrib-home-assistant-websocket/assets/141894/f6f8aca6-fcc3-4845-8c0e-0458bcd5a669)
### Example Flow
_No response_
### This package's version (not the Home Assistant add-on version)
0.57.2
### Is Node-RED running in Docker?
### Node-RED version
14.6.1
### Node.js version
unknown
### Additional context
_No response_
Kermit
September 9, 2024, 3:16pm
6
It has been changed in one of the latest releases nappyjim is running an older version of the HA nodes.
nappyjim
(Jim)
September 11, 2024, 12:21am
7
I am? Where do I update? I dont see update available anywhere. Clicking hamburger in NR, says I am on 4.0.2
Mikefila
(Mike Fila)
September 11, 2024, 12:51am
8
In the hamburger menu, manage palette. Update the home assistant websocket nodes.
nappyjim
(Jim)
September 11, 2024, 2:07am
9
Thanks. I updated and wow, it looks different lol. Search works better; now it was #2 on list.
