switch: !include rf_switches.yaml
switch 2: !include ir_switches.yaml
script: !include script.yaml
script 2: !include script_alexa.yaml
the script_alexa.yaml is not being loaded at all.
As explained in the troubleshooting guide, what does the following command show?
hass --script check_config --files
i think you have to rename the first script.yaml into something like script_1.yaml
still not working
script: !include main_script.yaml
script 2: !include alexa_script.yaml
and my yaml validates.
So please show us the output of the command I listed, and both the (correctly formatted - see the blue box at the top) entry in the configuration.yaml
, and the content of the script_alexa.yaml
file.
pi@piHass:~ $ hass --script check_config --files
Testing configuration at /home/pi/.homeassistant
17-04-28 18:47:36 INFO (MainThread) [homeassistant.setup] Setting up http
17-04-28 18:47:36 INFO (MainThread) [homeassistant.setup] Setting up recorder
17-04-28 18:47:36 INFO (MainThread) [homeassistant.setup] Setting up api
17-04-28 18:47:36 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
17-04-28 18:47:36 INFO (MainThread) [homeassistant.setup] Setting up history
17-04-28 18:47:36 INFO (MainThread) [homeassistant.setup] Setting up frontend
17-04-28 18:47:36 INFO (MainThread) [homeassistant.setup] Setting up updater
17-04-28 18:47:36 INFO (MainThread) [homeassistant.setup] Setting up sun
17-04-28 18:47:36 INFO (MainThread) [homeassistant.setup] Setting up climate
17-04-28 18:47:36 INFO (MainThread) [homeassistant.setup] Setting up notify
17-04-28 18:47:36 INFO (MainThread) [homeassistant.setup] Setting up script
17-04-28 18:47:36 INFO (MainThread) [homeassistant.setup] Setting up sensor
17-04-28 18:47:36 INFO (MainThread) [homeassistant.setup] Setting up emulated_hue
17-04-28 18:47:36 INFO (MainThread) [homeassistant.setup] Setting up automation
17-04-28 18:47:36 INFO (MainThread) [homeassistant.setup] Setting up discovery
17-04-28 18:47:36 INFO (MainThread) [homeassistant.setup] Setting up zone
17-04-28 18:47:36 INFO (MainThread) [homeassistant.setup] Setting up switch
17-04-28 18:47:36 INFO (MainThread) [homeassistant.setup] Setting up logbook
17-04-28 18:47:36 INFO (MainThread) [homeassistant.setup] Setting up camera
17-04-28 18:47:36 INFO (MainThread) [homeassistant.setup] Setting up config
17-04-28 18:47:36 INFO (MainThread) [homeassistant.setup] Setting up device_tracker
17-04-28 18:47:36 INFO (MainThread) [homeassistant.setup] Setting up zeroconf
17-04-28 18:47:36 INFO (MainThread) [homeassistant.setup] Setting up ios
yaml files (used / not used)
- /home/pi/.homeassistant/alexa_script.yaml
- /home/pi/.homeassistant/automation.yaml
- /home/pi/.homeassistant/cameras.yaml
- /home/pi/.homeassistant/configuration.yaml
- /home/pi/.homeassistant/groups.yaml
- /home/pi/.homeassistant/ir_switches.yaml
- /home/pi/.homeassistant/known_devices.yaml
- /home/pi/.homeassistant/main_script.yaml
- /home/pi/.homeassistant/rf_switches.yaml
- /home/pi/.homeassistant/script.yaml
- /home/pi/.homeassistant/switches.yaml
- /home/pi/.homeassistant/zones.yaml
not sure what good that’s gonna do ya with the lack of colors showing what was used and un-used, the alexa file says it was used, yet no scripts within were loaded. all i’m trying to do here is seperate the scripts that alexa can see in the emulated hue from my other scripts that alexa doesn’t need to know about. all i did was copy and paste existing, working, yaml code.
Now we just need the other information I asked for:[quote=“Tinkerer, post:5, topic:16642”]
both the (correctly formatted - see the blue box at the top) entry in the configuration.yaml, and the content of the script_alexa.yaml file.
[/quote]
i keep telling you that’s NOT the issue, but FINE.
emulated_hue:
type: alexa
host_ip: 10.11.12.23
exposed_domains:
- script
#script: !include script.yaml
alexa_script.yaml
game:
alias: 'Game'
sequence:
- service: switch.turn_on
entity_id: switch.tv_input
entity_id: switch.tv_three
media:
alias: 'Media Player'
sequence:
entity_id: switch.tv_four
server:
alias: 'Server'
sequence:
entity_id: switch.tv_five
antenna:
alias: 'Antenna'
sequence:
entity_id: switch.tv_zero
all_lights:
alias: "Lights"
sequence:
- service_template: >
{% if requested_state == 'on' %}
switch.turn_on
{% elif requested_state == 'off' %}
switch.turn_off
{% endif %}
entity_id: switch.switch_3
switch.turn_on
switch.turn_off
{% endif %}
entity_id: switch.switch_2
switch.turn_on
switch.turn_off
{% endif %}
entity_id: switch.switch_4
switch.turn_on
switch.turn_off
{% endif %}
entity_id: switch.switch_5
wall:
alias: "Wall"
sequence:
service_template: >
switch.turn_on
switch.turn_off
{% endif %}
mirror:
alias: "Mirror"
sequence:
service_template: >
switch.turn_on
switch.turn_off
{% endif %}
desk:
alias: "Desk"
sequence:
service_template: >
switch.turn_on
switch.turn_off
{% endif %}
air:
alias: "A-C"
sequence:
service_template: >
switch.turn_on
switch.turn_off
{% endif %}
entity_id: switch.switch_1
tv:
alias: "TV"
sequence:
service_template: >
switch.turn_on
switch.turn_off
{% endif %}
entity_id: switch.tv_power
soundbar:
alias: "Speaker"
sequence:
service_template: >
switch.turn_on
switch.turn_off
{% endif %}
entity_id: switch.soundbar_power
# apple:
# alias: "Apple"
# sequence:
# service_template: >
# {% if requested_state == 'pause' %}
# switch.turn_off
# {% elif requested_state == 'play' %}
# switch.turn_on
# {% endif %}
# entity_id: switch.apple_play_pause
comp:
alias: "Computer"
sequence:
service_template: >
switch.turn_on
switch.turn_off
{% endif %}
set_thermostat:
alias: "Thermostat"
sequence:
- service: climate.set_temperature
data_template:
entity_id: climate.cooler
temperature: "{{ requested_level }}"
Well, if you’re going to take issue with my trying to help you, I won’t bother
sounds more like you won’t admit it’s not the yaml code causing it not to load.
