I have the following automation. These are two switches (the first two entries); they are also grouped together. The third automation is supposed to work on that group as a whole:
- id: 'wall_switch_ch3_lampe_gauche'
initial_state: True
- platform: state
entity_id: sensor.rf433_switch_payload_full
condition:
condition: template
value_template: "{{ states.sensor.rf433_switch_payload_full.state[-6:] == '1A97E2' }}"
entity_id: light.ch3_lampe_gauche
service: homeassistant.toggle
- id: 'wall_switch_ch3_lampe_droite'
initial_state: True
- platform: state
condition:
condition: template
value_template: "{{ states.sensor.rf433_switch_payload_full.state[-6:] == '1F97E9' }}"
entity_id: light.ch3_lampe_droite
- id: 'wall_switch_ch3_all_lamps'
initial_state: True
- platform: state
condition:
condition: template
value_template: "{{ states.sensor.rf433_switch_payload_full.state[-6:] == '5A4BE1' }}"
entity_id: group.ch3
For the sake of completeness, the group:
ch3:
entities:
- light.ch3_lampe_gauche
- light.ch3_lampe_droite
What happens is that when the 5A4BE1
signal is received (approximately speaking), the third automation fires and toggles the state of each switch separately.
In other words, when both switches are off
or on
- everything is OK (they both turn to the other state), but when one of the switches is on
while the other is off
, the former flips to off
and the latter to on
(and vice versa). Instead of both turning on
or off
, depending on the state of the group.
Why is it so?
