I am having trouble getting the visibility to work for this automation. I checked the other part of the automation by setting visible: True and it works.
automation visibility_entity_group:
- platform: state
entity_id:
- group.a
- group.b
- group.c
- service: group.set_visibility
data_template:
entity_id: '{{ trigger.entity_id }}'
visible: "{{ is_state('trigger.to_state.state', 'on') }}"
The example below did it in script . Could it be that visibility can only be set in script like this?
script:
group_visibility:
sequence:
data_template:
entity_id: '{{ entity_id }}'
visible: '{{ is_state(cond, visible_state) }}'
https://home-assistant.io/docs/configuration/group_visibility/
I get these errors if I use single quotes, or no quotes or use ==.
2017-11-16 16:33:41 ERROR (MainThread) [homeassistant.components.automation] while scanning a quoted scalar
in “/Users/xxx/.homeassistant/configuration.yaml”, line 4011, column 62
found unexpected end of stream
in “/Users/xxx/.homeassistant/configuration.yaml”, line 4016, column 41
2017-11-16 16:42:21 ERROR (SyncWorker_1) [homeassistant.util.yaml] while parsing a block mapping
in “/Users/xxx/.homeassistant/configuration.yaml”, line 4010, column 9
expected , but found ‘’
in “/Users/xxx/.homeassistant/configuration.yaml”, line 4011, column 56
2017-11-16 16:42:21 ERROR (MainThread) [homeassistant.components.automation] while parsing a block mapping
