Hi, I am new to HA so I’m still in the learning process heh. I have been reading here and there regarding docs. Right now I have a confusion about how HA works with YAML files. I have the following configuration.yaml
file:
# Core Configuration. Do not remove.
default_config:
frontend:
themes: !include_dir_merge_named themes
# Text to speech
tts:
- platform: google_translate
automation: !include includes/automations.yaml
There are a default automations.yaml
located at the same level where configuration.yaml
does exist.
If I manage automation from the UI the new ones get created in the default automations.yaml
and not the one located at includes/automations.yaml
. Also, automation defined inside includes/automations.yaml
does not show up in the UI/
I have also seen that some example automation like the ones posted at Actions | Home Assistant Companion Docs does not have an ID (not sure if this is mandatory or not) however the ones created from the UI do have one.
Why newly added automation is using the default file and not the one within the includes? Why the ones defined at includes/automations.yaml
does not show up in the UI?
