I run Pi-Hole + Unbound recursive DNS so only the 13 root nameservers are my DNS and no device is allowed to go around that.
I have been noticing my OPNSense firewall logs going nuts with a device spamming with Cloudflare DNS requests.
I have a dynamic rule to block devices from using DNS-over-TLS and DNS-over-HTTPS which makes impossible to block their ADs and personal data tracking, you know, you cannot just block 443 ( DNS-over-HTTPS) and call it a day and blocking 853 isn’t really solving the problem.
While checking NTOPNG, I got this little surprise. I don’t think this is correct or right for the matter.
If I am running home assistant locally to avoid control, the last thing I need is home assistant itself forcing DNS servers on me.
Is there a way to completely remove/disable this??
It must be a way to stop this.
