Is there a reason why docker version 2025.8.3 have not the latest tag? I get shown that there is an update for the docker container, but when I try to update I still get version 2025.8.2.
docker pull ghcr.io/home-assistant/home-assistant:stable
Sorry take the wrong image.
Looks like this is still an issue on Docker Hub, both were pushed 10 days ago with 2025.8.2:
https://hub.docker.com/r/homeassistant/home-assistant/tags?name=stable
https://hub.docker.com/r/homeassistant/home-assistant/tags?name=latest
I figured these would be in sync with GitHub Container Registry, so there may still be an issue.
