No I cannot. I tried LAN IP, localhost, 127.0.0.1, no luck. It seems that local publishing of file is not working. I can’t believe I need to restart HA after image was added - I need to add images continusously when webcam detects movement, I cannot restart HA everytime it happens.
I can confirm that after HA restart the image is visible on LAN under http://<local_IP>:8123/local/test_image.jpg
However, it is still not sent to telegram. Tried:
image: /config/www/test_image.jpg
image: /local/test_image.jpg
image: 127.0.0.1/local/test_image.jpg
image: 127.0.0.1:8123/local/test_image.jpg
image: <local_IP>/local/test_image.jpg
image: <local_IP>:8123/local/test_image.jpg
image: http://<local_IP>/local/test_image.jpg
image: http://<local_IP>:8123/local/test_image.jpg
