Why I probably will not contribute to Home Assistant (any more). My story:
I have found a bug in Homematic component YAML configuration
I found solution that works for me within of 1-2 hours, but it was rather a workaround than a correct solution
I spend another 6-7 hours to find correct solution that can be accepted as a PR (it took lot of time for me since I am not that deep in HA python development and first had to understand some basic things)
I submitted a small pull request to home assistant core (just 2 lines of code, Link to PR)
the pull request was declined because of ADR-0010 rule (ADR-0010) that says “Changes to existing YAML configuration for these same existing integrations, will no longer be accepted.”
Unfortunately I dont have enough knowledge for now to do such a big change as requested by the PR reviewer (refactor the whole component to use config flow). This rule generally is ok for me, but there must be exceptions for small bugfixes. I see no reason not to do so. Why not to accept small bugfixes for yaml even if is deprecated in this context. It is completely demotivating if PR is declined without really good reason except strongly following the rule that is, in my opinion, not really well-thought-out.
After that, for me, it is easier to do changes I need locally than spend time and, at the end, ending with a declined PR.
