I noticed that the Amazon Alexa integration is used in 95% of installations:
Which made me wonder if it was somehow enabled on my install even though I do not use Amazon Alexa.
I have found that the integration is listed under /config/info however it does not appear under /config/integrations (nor does it exist in my configuration.yaml) so I’m not really sure how I can remove it.
Is this the expected behaviour? How do I disable the Alexa integration?
