This automation runs long time without problems, but now it does not trigger. It should trigger every time the state changes to “true”. Works for month but now it´s broken???
The sensor is updating his state correct but automation is not triggering, was there a change in automations for hass i did not see?
alias: Wenn Szene Check nichts aktiv -> scene.Keine Szene gewählt
hide_entity: true
- platform: state
entity_id: sensor.scene_check_nothing_active
state: 'true'
service: input_select.select_option
entity_id: input_select.scene_select
option: "Keine Szene gewählt"
There are multiple sensor.scene_check_xxxxxxxxxx and they all change immediately like they should. But the automations that should update the input_select to a specific option are not working. Sometimes they do sometimes not. All i did in the last weeks was update of hass. The automations have not changed.
@Tinkerer seems to be a caching bug of my server connection. The things i tried never get their way to the server. After restarting the whole machine it´s working again. No idea what that was.
