Kind of in a snit here after an hour or so of searching and reading older, related, posts about the futility of being able to remove a device from an integration without removing the entire integration.
Why is this still a thing, years later from when the initial reports and feature requests started coming in?
Do you just disable the device and ignore it? Why won’t the app clean-up the orphaned devices from the dashboard?
Most have this ability, except for a few third party integrations that do not follow the guidelines. e.g. here are two integrations with multiple devices I picked at random:
Deconz is another culprit for not allowing device deletion via the UI. In the case of Deconz i will delete it from the Deconz/Phoscon UI, then sync or reload the addon in HA to find it removed.
Specifically, I’m addressing my blink integration - there are five devices registered with the integration but I wish to only remove one. I cannot however, without apparently removing the entire integration and re-rolling. Geh.
What I’m understanding from your responses is that the problem lies with the developers not providing a fully-featured implementation of their addon.
Unfortunately, I’m learning too late, after years of investment and growth, that Blink is just a way-more ghetto version of Ring.
