Have your set your elevation correctly in ft? And what version are you using? This weather integration didn’t convert the elevation correctly for imperial units until recently.
I did not restart HA. I just hit Save, and the numbers fixed themselves.
(I do know HA devs are trying to actively move away from having to restart after every little configuration change - their intent: any UI updates should not require a restart)
Changing coordinate systems or default parameters of home assistant itself isn’t always handled well by each integration, but it seems met does handle it.
Hi all. In HA settings, I’m set to imperial, but next to the altitude it says “Meters” and I can’t seem to change that. In the met.no configuration, the indication next to the altitude simply says “M”. Its temp reports have been way too low, so I used the number of meters instead, and it indicates conditions correctly. I don’t know if the HA altitude setting is actually requiring meters or not, and I don’t think anything else I’m currently using requires that, but it looks like it expects meters, even though I’ve always been set to imperial. Met.no specifies in their api docs “Whole Meters”, so I wonder if metric altitude is all they can use? Two different issues I know (HA and met.no), but clarification or correction would be helpful. Thanks much.
