Hi. Im trying to compile this:
esphome:
friendly_name: zwave-gateway
project:
version: "3.0"
#wifi:
# ssid: !secret wifi_ssid
# password: !secret wifi_password
# ## Enable fallback hotspot (captive portal) in case wifi connection fails
# ap:
# ssid: "Zwave-Gateway Fallback Hotspot"
# password: "yCnsOoWJzqoP"
esp32:
board: esp32-poe
framework:
type: esp-idf
external_components:
- source: github://oxan/esphome-stream-server
dashboard_import:
package_import_url: github://tube0013/tube_gateways/models/current/tubeszb-zw-kit/tubeszb-zw.yaml
#Olimex ESP32-PoE Ethernet
ethernet:
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
power_pin: GPIO12
# Optional manual IP
#manual_ip:
#static_ip:
#gateway:
#subnet: 255.255.255.0
# Enable logging
logger:
level: DEBUG
# Enable Home Assistant API
api:
reboot_timeout: 0s
encryption:
key: "xxxxx"
ota:
- platform: esphome
password: "xxxxx"
web_server:
port: 80
button:
- platform: restart
name: "Restart the ESP32 Device"
uart:
rx_pin: GPIO16
tx_pin: GPIO5
baud_rate: 115200
stream_server:
buffer_size: 2048
uart_id: uart_bus
# id: ss
port: 6638 # optional, default is 6638
binary_sensor:
- platform: stream_server
connected:
name: "TubesZB ZW Serial Connected"
but its failing with the following error:
INFO ESPHome 2024.7.3
INFO Reading configuration /config/esphome/zwave-gateway.yaml...
WARNING GPIO12 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
WARNING GPIO5 is a strapping PIN and should only be used for I/O with care.
INFO Generating C++ source...
INFO Compiling app...
Processing zwave-gateway (board: esp32-poe; framework: espidf; platform: platformio/[email protected])
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
- framework-espidf @ 3.40407.240606 (4.4.7)
- tool-cmake @ 3.16.4
- tool-ninja @ 1.7.1
- toolchain-esp32ulp @ 2.35.0-20220830
- toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
Reading CMake configuration...
Dependency Graph
|-- noise-c @ 0.1.4
|-- ArduinoJson @ 6.18.5
*** [.pioenvs/zwave-gateway/src/esphome/components/captive_portal/captive_portal.o] Source `src/esphome/components/captive_portal/captive_portal.cpp' not found, needed by target `.pioenvs/zwave-gateway/src/esphome/components/captive_portal/captive_portal.o'.
========================== [FAILED] Took 2.71 seconds ==========================
Where the captive_portal dependency comes from?
