System Health
version | core-2021.12.1 |
installation_type | Home Assistant Supervised |
dev | false |
hassio | true |
docker | true |
user | root |
virtualenv | false |
python_version | 3.9.7 |
os_name | Linux |
os_version | 5.14.21-2-MANJARO |
arch | x86_64 |
timezone | Europe/London |
Home Assistant Community Store
GitHub API | ok |
Github API Calls Remaining | 4962 |
Installed Version | 1.18.0 |
Stage | running |
Available Repositories | 971 |
Installed Repositories | 3 |
Home Assistant Cloud
logged_in | false |
can_reach_cert_server | ok |
can_reach_cloud_auth | ok |
can_reach_cloud | ok |
Home Assistant Supervisor
host_os | Manjaro Linux |
update_channel | stable |
supervisor_version | supervisor-2021.12.1 |
docker_version | 20.10.11 |
disk_total | 95.7 GB |
disk_used | 88.4 GB |
healthy | true |
supported | failed to load: Unsupported |
supervisor_api | ok |
version_api | ok |
installed_addons | Hey Ada! (1.1.1), NGINX Home Assistant SSL proxy (3.0.2), AdGuard Home (4.2.0), Google Assistant SDK (2.5.0), Check Home Assistant configuration (3.9.0), Let’s Encrypt (4.12.0), Almond (2.0.1), MariaDB (2.4.0), File editor (5.3.3), Terminal & SSH (9.2.1), ESPHome (2021.12.0), Z-Wave JS (0.1.50) |
Lovelace
dashboards | 2 |
resources | 1 |
views | 2 |
mode | storage |
I have installed Home Assistant Supervisor on Arch Linux (I know its unsupported). Most things seem to work flawlessly, except MPD media player.
I have installed 2 different versions of mopidy one after another with no luck. Well I say no luck, one time after a reboot it worked but took over all sound from my laptop (I could not play any other sounds like playing youtube videos did not produce any sound due to no sound devices available in my settings, except the dummy output)
Surely there must be a simple way to play TTS sounds from the host system.
E.g.
I would like to be able to have a voice that will speak notifications, like when my friend goes on his xbox I want home assistant to announce this.
Ive spent 4 days trying many things and still, I cannot get this simple thing done. There are a few other posts about this subject but all are related to raspberry pi and all posts claim the problem was solved but no one explains how there problem was solved.
