Why is it so difficult to play TTS from host system?
System Health
version core-2021.12.1
installation_type Home Assistant Supervised
dev false
hassio true
docker true
user root
virtualenv false
python_version 3.9.7
os_name Linux
os_version 5.14.21-2-MANJARO
arch x86_64
timezone Europe/London
Home Assistant Community Store
GitHub API ok
Github API Calls Remaining 4962
Installed Version 1.18.0
Stage running
Available Repositories 971
Installed Repositories 3
Home Assistant Cloud
logged_in false
can_reach_cert_server ok
can_reach_cloud_auth ok
can_reach_cloud ok
Home Assistant Supervisor
host_os Manjaro Linux
update_channel stable
supervisor_version supervisor-2021.12.1
docker_version 20.10.11
disk_total 95.7 GB
disk_used 88.4 GB
healthy true
supported failed to load: Unsupported
supervisor_api ok
version_api ok
installed_addons Hey Ada! (1.1.1), NGINX Home Assistant SSL proxy (3.0.2), AdGuard Home (4.2.0), Google Assistant SDK (2.5.0), Check Home Assistant configuration (3.9.0), Let’s Encrypt (4.12.0), Almond (2.0.1), MariaDB (2.4.0), File editor (5.3.3), Terminal & SSH (9.2.1), ESPHome (2021.12.0), Z-Wave JS (0.1.50)
Lovelace
dashboards 2
resources 1
views 2
mode storage
I have installed Home Assistant Supervisor on Arch Linux (I know its unsupported). Most things seem to work flawlessly, except MPD media player.
I have installed 2 different versions of mopidy one after another with no luck. Well I say no luck, one time after a reboot it worked but took over all sound from my laptop (I could not play any other sounds like playing youtube videos did not produce any sound due to no sound devices available in my settings, except the dummy output)
Surely there must be a simple way to play TTS sounds from the host system.
E.g.
I would like to be able to have a voice that will speak notifications, like when my friend goes on his xbox I want home assistant to announce this.
Ive spent 4 days trying many things and still, I cannot get this simple thing done. There are a few other posts about this subject but all are related to raspberry pi and all posts claim the problem was solved but no one explains how there problem was solved.
Have a look here, maybe it helps…
And yes, this will work without Nabu Casa too, with small situation dependent changes…
Thanks, I will give it a go. My only concern is having to install VLC… seriously, how many additional software need to be installed? I run HA on a laptop, it has all the modern hardware it needs, its an Arch Linux installation (possibly the most advanced Linux desktop to install and maintain) so has everything and anything available to me software-wise.
I cannot fathom why I need to install more software (VLC) to play a sound…
Surely it should be very simple to just play sounds via the hosts Pulse audio or ALSA server…
Well, I don’t know so much about Aarch, but VLC is in the Linux world like Windows Media Player on Windows. Most Linux distro’s have it on board out of the box. VLC is very good piece of software.
Why it has to be done this way in HA, I don’t know. I’m also just a often struggling user :smiley: :smiley: :smiley:
Well, this way it worked out for me, it works now flawlessly for weeks. The way there is a bit strange, but it got me to the destination :wink:
