klogg
(Klogg)
April 6, 2023, 4:43pm
1
I’m trying to use the last_changed
of the entity_id
that triggers my automation like this:
- platform: state
entity_id:
- switch.hall_light
- switch.shed_light
to: unavailable
- service: input_datetime.set_datetime
entity_id: >
input_datetime.time_became_unavailable
datetime: >
{{ states.trigger.entity_id.last_changed }}
but it gives me an error,
Template variable warning: 'None' has no attribute 'last_changed' when rendering '{{ states.trigger.entity_id.last_changed }}'
Why?
For the record:
The trigger
variable is already a state object, so there’s no reason to
use states
… you can use trigger.to_state.last_changed
or just use now()
entity_id:
- input_datetime.time_became_unavailable
datetime: "{{ now() }}"
Yeah, what @Didgeridrew said. And see:
BTW, now() might not be the same as last_changed, since only an attribute might have changed. Oops, I missed there is a “to” specified.
klogg
(Klogg)
April 6, 2023, 9:23pm
4
Thanks to both of you.
As far as using now()
I was doing that (and it worked well) but I now have a reason to want to use last_changed
. The reason is not related to setting a datetime
, I used that as simple illustration, but is very specific to my narrow use case but is to do with scripts calling scripts with the possibility of queues forming (thanks @pnbruckner ).
