My project is about automating my garden. I have B-Hyve valves and Ecowitt soil moistture sensors. I have 3 watring lines with that setup. I learned for instance that the cucumbers consume water is really different from the way tomatoes consume water. So, I have 1 line for cucumbers (frequent shorter watering cycles (31%-48% soil moisture), 1 for tomatoes (long infrequent cycles) and 1 for smaller plants like herbs.
My problem is that I often have to restart HA so that my automations will execute. For example, yesterday, cucumber moisture was 30% and the automation is supposed to be triggered by a moistture below 31% but it wasn’t triggered. I simply did a restart of HA via the dev tools menu and the automation got triggered right away.
I am now thinking of doing periodic restarts (obviously automated ones) of HA but it’s not normal and I was wondering if anyboby else ran into this problem.
So why didn’t the automation trigger?
What did the traces say?
I’m also very confused why it suddenly triggered when you restarted HA.
Because a normal numeric trigger shouldn’t have triggered at that point.
I think it’s a lot better if you post the automation
Here’s the YAML for the tomatoes line. Please take note that these automations normally tigger fine, until they don’t, which gets fixed with a restart.
You should really try to use entity ids instead of device ids.
It easier to read and it will be easier to replace failing devices later.
Other than that I can only see one issue with your automation and that is the timeout on the watering.
If you do not succeed in getting the value above 30 in those 30 minutes, then it will be able to trigger again, because it will not pass from above 30 to below 30.
A common mistakes is that the trigger is set to only trigger when the threshold gets passed.
Just to be certain, are you saying that it’s a common mistake that the automation is only triggered at the exact time that a certain value is reached (For example, exactly when a clock ticks to12:00), rather than that the automation is triggered any time that the value is at or below that threshold, for example 12:00 and all values beyond it)?
Yes it triggers when. It goes from before 12:00 and to after 12:00.
It does not trigger when going from 12:30 to
12:31
It does trigger if it goes from 11:30 to12:31.
It had to pass the trigger value.
It depends how you want it to run. If you want to check the moisture at a certain time say 5 pm. Then trigger on time. If you want to check when the moisture level drops between certain times, the trigger by the sensor value changing and condition between times. There are probably more efficient ways of doing it but if you are questioning this way of doing it templates may be a step too far.
Here’s an example of how I rewrote my automations, and it’s working great so far. The trigger is any change of state of my soil moisture sensor. Then the humidity threshold is in the condition for watering.
Just a guess, but you have a condition below 33, and then asking it to trigger above 60, as 60 is always bigger than 33, it will have stopped the automation before it gets to that trigger.
This automation is worse then the one you started with.
Are you willing to listen to our advices or do you first want to flood your garden?
[EDIT] I just realized this was a different thread than what I was expecting.
The automation is bad but my second sentence above is not something I should have written if I had understood it was this thread. Sorry about that.
