Due to possible throttling issues on the API the Growatt integration uses, there’s an option to disable automatic polling and then allow you to poll less frequently. So I created what I thought would be the following very simple automation to get the two devices the integration provides to update at 15 min intervals:
alias: Update Device Automation
description: ""
- platform: time_pattern
minutes: /15
condition: []
- service: homeassistant.update_entity
device_id:
- 27255d1a5e92a4cb5f1adb04ca80ffe6
- f70f0d3dff46f49f1366aebe253b05aa
data: {}
mode: single
This was created through the UI. But it doesn’t cause an update and the trace log shows:
Triggered by the time pattern at 5 May 2023 at 18:15:00
Home Assistant Core Integration: Update entity NWCTCH107G, Home solar Total
Stopped because an error was encountered at 5 May 2023 at 18:15:00 (runtime: 0.01 seconds)
extra keys not allowed @ data['device_id']
I’ve tried various options using the area and the devices, but only if I break them out to the individual entities themselves will it run. Why does the UI and some of the docs imply the device/area alone will work?
Home Assistant 2023.5.1
Supervisor 2023.04.1
Operating System 10.1
Frontend 20230503.2 - latest
Thanks for any pointers, I’ve searched and searched and found nothing that suggests I’m doing anything wrong…
