Looking at the latest releases for Supervisor, I see that it is at 2022.04.02, but my HA installation does not seem to pickup the latest releases, so I won’t be able to update to it. Does the Supervisor or the HA core control the Supervisor version to be pulled into an installation? Is there a way to manually install a specific version of the Supervisor (similar to ha cli)? Thanks.
Supervisor polls a version file and updates itself if it is available.
The current GitHub stable.json file for supervisor lists the active version as 2022.04.0. Are you sure you aren’t looking at a dev build?
"channel": "stable",
"supervisor": "2022.04.0",
