Try this code
[{"id":"5d1278d1.1ca3d8","type":"inject","z":"51045e07.bbf87","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":200,"y":1180,"wires":[["eb52e864.4e1588"]]},{"id":"eb52e864.4e1588","type":"api-call-service","z":"51045e07.bbf87","name":"Licht Studiotisch","server":"1a33ac7a.3d8894","version":1,"debugenabled":false,"service_domain":"light","service":"toggle","entityId":"light.tz3000_dbou1ap4_ts0505a_level_light_color_on_off","data":"{\"transition\":\"5\"}","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"msg","mustacheAltTags":false,"x":600,"y":1180,"wires":[[]]},{"id":"1a33ac7a.3d8894","type":"server","name":"Home Assistant","legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":false,"cacheJson":true}]
You first copy it and go to nodered then CTRL+I, paste the code in window and import, then deploy and try
