Below automation should trigger this trigger (I executed it manually):
value_template: '{{ states[''sensor.entity_offline_zigbee''].state | int > 0 }}'
because value of this sensor is equal 1 (checked in the developer tools in the template section). But it going to the default option:
Automation:
alias: '[00] input_select.mobile_2_info - Update'
description: ''
value_template: '{{ states[''sensor.entity_offline_tuya''].state | int > 0 }}'
value_template: '{{ states[''sensor.entity_offline_sensor''].state | int > 0 }}'
- platform: state
entity_id: timer.mobile_2_zuza_turn_off_30
to: active
- platform: state
to: idle
- platform: state
entity_id: input_boolean.mobile_2_roomba
to: 'on'
- platform: state
to: 'off'
- platform: state
entity_id: timer.mobile_2_security_turn_on
to: active
- platform: state
to: idle
- platform: state
entity_id: input_boolean.mobile_2_security
to: 'on'
- platform: state
to: 'off'
value_template: '{{ states[''sensor.entity_offline_tuya''].state | int == 0 }}'
value_template: '{{ states[''sensor.entity_offline_sensor''].state | int == 0 }}'
value_template: '{{ states[''sensor.entity_offline_zigbee''].state | int == 0 }}'
value_template: '{{ states[''input_select.mobile_2_info''].state | int == 0 }}'
condition: []
- choose:
- conditions:
- condition: trigger
sequence:
- service: input_select.select_option
option: '5'
entity_id: input_select.mobile_2_info
- conditions:
sequence:
option: '4'
- conditions:
sequence:
option: '2'
- conditions:
sequence:
option: '3'
- conditions:
sequence:
option: '1'
- service: telegram_bot.send_message
message: Tuya devices are offline.
target: 000
- conditions:
sequence:
option: '1'
target: 000
message: Motion sensors are offline.
- conditions:
sequence:
option: '1'
target: 000
message: Zigbee devices are offline.
default:
option: '0'
mode: single
Any idea why it doesn’t triggers the specific trigger?
