Why is this automation running?
I have an automation running on every temperature change. But I have multiple conditions to abort the automation. As long as I know the condition need all to be true before the actions are executed. But I have 1 condition, the
  - condition: template
    value_template: '{{ states("sensor.heating_kitchen") | int < 28 }}'
this one is false even if all other are false. But the action with the action notify is still running but I have no idea why.
Here is the full automation
alias: Wenn im Küche zu kalt, Heizung hoch drehen
hide_entity: true
initial_state: true
####Bei jeder veränderung der Raumtemperatur
  - platform: state
    entity_id: sensor.kitchen_multi_sensor_temperature
condition:
    value_template: '{{ states.sensor.kitchen_multi_sensor_temperature.state|int < (states.input_number.kitchen_temp_max.state|float - 0.5) }}'
  - condition: state
    entity_id: input_boolean.nobody_home
    state: 'off'
  - condition: state
    entity_id: input_boolean.sleepmode
    state: 'off'
  - condition: state
    entity_id: binary_sensor.kitchen_window_sensor
    state: 'off'
  #####Kitchen Heating Value Set
  - service: climate.set_temperature
      entity_id: climate.kitchen_heating_heating_1
      temperature: 28
  - service: notify.devices_christian
      message: "Küche temp to low"
You are correct. I was thinking of triggers. I’ve deleted my post to prevent misleading anyone.
There’s not enough info here. What are the values of each sensor when this is running and you don’t expect it? Is sensor.heating_kitchen a template sensor?
