I am trying to use the conversation and the intent_script but it always says my config is invalid no matter what. pls help
# Example base configuration.yaml entry for conversation
conversation:
intents:
HouseTemperature:
- What is the temperature
- What is the temperature in the house
- Whats the temperature
- Whats the thermostat set to
- How hot is the house
- How cold is the house
- House temperature
BasementLights:
- Set basement lights to [the color] {color}
- Set davids lights to [the color] {color}
- Make basement lights [the color] {color}
- Make davids lights [the color] {color}
Garage:
- Open [the] garage
- Close [the] garage
GarageStatus:
- Is [the] garage open
- Is [the] garage closed
intent_script:
HouseTemperature:
speech:
text: It is currently {{ states.sensor.3family_room_temperature }} degrees in the house.
BasementLights:
speech:
text: Set the Basement Lights to {{ color }}.
service: light.turn_on
entity_id: light.basement_lights_main
rgb_color:
- "{% if color == 'red' %}255{% else %}0{% endif %}"
- "{% if color == 'green' %}255{% else %}0{% endif %}"
- "{% if color == 'blue' %}255{% else %}0{% endif %}"
- "{% if color == 'purple' %}255{% else %}0{% endif %}"
- "{% if color == 'pink' %}255{% else %}0{% endif %}"
- "{% if color == 'yellow' %}255{% else %}0{% endif %}"
- "{% if color == 'orange' %}255{% else %}0{% endif %}"
- "{% if color == 'gold' %}255{% else %}0{% endif %}"
- "{% if color == 'brown' %}255{% else %}0{% endif %}"
Garage:
speech:
text: Toggled the Garage door button
service: switch.toggle
entity_id: switch.garage_bot
GarageStatus:
speech:
text: The Garage door is {{ states.cover.garage_bot }}
