Well, here we go:
"external perimeters extrusion width": "0.45mm",
"perimeters extrusion width": "0.45mm",
"infill extrusion width": "0.45mm",
"solid infill extrusion width": "0.45mm",
"top infill extrusion width": "0.40mm",
"support material extrusion width": "0.35mm",
"first layer extrusion width": "0.80mm",
"max_layer_z": "64.2",
"objects_info": "{\"objects\":[{\"name\":\"LeadScrewBrackets-Idler.stl id:0 copy 0\",\"polygon\":[[132.246,75.849],[139.205,77.099],[163.293,85.896],[166.716,92.146],[166.714,129.146],[163.178,134.146],[121.106,134.146],[115.005,130.706],[105.076,117.388],[102.511,108.948],[102.511,104.948],[116.723,104.947],[116.724,92.696],[114.122,92.692],[114.122,92.292],[116.724,92.292],[116.725,84.850],[102.512,84.848],[102.512,80.848],[106.048,75.847]]}]}",
"filament used [mm]": "8298.78",
"filament used [cm3]": "19.96",
"filament used [g]": "25.35",
"filament cost": "0.63",
"total filament used [g]": "25.35",
"total filament cost": "0.63",
"total filament used for wipe tower [g]": "0.00",
"estimated printing time (normal mode)": "2h 48m 12s",
"estimated printing time (silent mode)": "2h 50m 6s",
"estimated first layer printing time (normal mode)": "2m 14s",
"estimated first layer printing time (silent mode)": "2m 14s",
"prusaslicer_config": "end",
"arc_fitting": "disabled",
"autoemit_temperature_commands": "1",
"automatic_extrusion_widths": "0",
"automatic_infill_combination": "0",
"automatic_infill_combination_max_layer_height": "100%",
"avoid_crossing_curled_overhangs": "0",
"avoid_crossing_perimeters": "0",
"avoid_crossing_perimeters_max_detour": "0",
"bed_custom_model": "",
"bed_custom_texture": "",
"bed_shape": "0x0,250x0,250x210,0x210",
"bed_temperature": "90",
"bed_temperature_extruder": "0",
"before_layer_gcode": ";BEFORE_LAYER_CHANGE\\nG92 E0.0\\n;[layer_z]\\n\\n",
"between_objects_gcode": "",
"binary_gcode": "0",
"bottom_fill_pattern": "monotonic",
"bottom_solid_layers": "4",
"bottom_solid_min_thickness": "0.5",
"bridge_acceleration": "1000",
"bridge_angle": "0",
"bridge_fan_speed": "50",
"bridge_flow_ratio": "0.95",
"bridge_speed": "30",
"brim_separation": "0",
"brim_type": "outer_only",
"brim_width": "0",
"chamber_minimal_temperature": "0",
"chamber_temperature": "0",
"color_change_gcode": "M600\\nG1 E0.3 F1500 ; prime after color change",
"colorprint_heights": "",
"compatible_printers_condition_cummulative": "\"printer_notes=~/.*PRINTER_VENDOR_PRUSA3D.*/ and printer_notes=~/.*PRINTER_MODEL_MK3.*/ and nozzle_diameter[0]==0.4\";\"nozzle_diameter[0]!=0.8 and printer_model!=\\\"MK2SMM\\\" and printer_notes!~/.*MINI.*/ and printer_notes!~/.*PG.*/ and ! (printer_notes=~/.*PRINTER_VENDOR_PRUSA3D.*/ and printer_notes=~/.*PRINTER_MODEL_MK(2.5|3).*/ and single_extruder_multi_material) and printer_model!=\\\"MK3.5\\\"\"",
"complete_objects": "0",
"cooling": "1",
"cooling_perimeter_transition_distance": "0",
"cooling_slowdown_logic": "uniform_cooling",
"cooling_tube_length": "5",
"cooling_tube_retraction": "91.5",
"custom_parameters_filament": "\"\"",
"custom_parameters_print": "",
"custom_parameters_printer": "",
"default_acceleration": "1000",
"default_filament_profile": "\"Prusament PLA\"",
"default_print_profile": "0.15mm QUALITY @MK3",
"deretract_speed": "0",
"disable_fan_first_layers": "3",
"dont_support_bridges": "1",
"draft_shield": "disabled",
"duplicate_distance": "6",
"elefant_foot_compensation": "0.2",
"enable_dynamic_fan_speeds": "0",
"enable_dynamic_overhang_speeds": "0",
"end_filament_gcode": "\"; Filament-specific end gcode\"",
"end_gcode": "{if layer_z < max_print_height}G1 Z{z_offset+min(max_layer_z+1, max_print_height)} F720 ; Move print head up{endif}\\nG1 X0 Y200 F3600 ; park\\n{if layer_z < max_print_height}G1 Z{z_offset+min(max_layer_z+49, max_print_height)} F720 ; Move print head further up{endif}\\nG4 ; wait\\nM221 S100 ; reset flow\\nM900 K0 ; reset LA\\n{if print_settings_id=~/.*(DETAIL @MK3|QUALITY @MK3|@0.25 nozzle MK3).*/}M907 E538 ; reset extruder motor current{endif}\\nM104 S0 ; turn off temperature\\nM140 S0 ; turn off heatbed\\nM107 ; turn off fan\\nM84 ; disable motors\\n; max_layer_z = [max_layer_z]",
"ensure_vertical_shell_thickness": "enabled",
"external_perimeter_acceleration": "0",
"external_perimeter_extrusion_width": "0.45",
"external_perimeter_speed": "25",
"external_perimeters_first": "0",
"extra_loading_move": "-2",
"extra_perimeters": "0",
"extra_perimeters_on_overhangs": "0",
"extruder_clearance_height": "20",
"extruder_clearance_radius": "45",
"extruder_colour": "\"\"",
"extruder_offset": "0x0",
"extrusion_axis": "E",
"extrusion_multiplier": "1",
"extrusion_width": "0.45",
"fan_always_on": "1",
"fan_below_layer_time": "20",
"filament_abrasive": "0",
"filament_colour": "#FF0000",
"filament_cooling_final_speed": "3.4",
"filament_cooling_initial_speed": "2.2",
"filament_cooling_moves": "4",
"filament_cost": "25",
"filament_density": "1.27",
"filament_deretract_speed": "nil",
"filament_diameter": "1.75",
"filament_infill_max_crossing_speed": "0",
"filament_infill_max_speed": "0",
"filament_load_time": "0",
"filament_loading_speed": "28",
"filament_loading_speed_start": "3",
"filament_max_volumetric_speed": "8",
"filament_minimal_purge_on_wipe_tower": "15",
"filament_multitool_ramming": "0",
"filament_multitool_ramming_flow": "10",
"filament_multitool_ramming_volume": "10",
"filament_notes": "\"\"",
"filament_purge_multiplier": "100%",
"filament_ramming_parameters": "\"120 100 6.6 6.8 7.2 7.6 7.9 8.2 8.7 9.4 9.9 10.0| 0.05 6.6 0.45 6.8 0.95 7.8 1.45 8.3 1.95 9.7 2.45 10 2.95 7.6 3.45 7.6 3.95 7.6 4.45 7.6 4.95 7.6\"",
"filament_retract_before_travel": "nil",
"filament_retract_before_wipe": "nil",
"filament_retract_layer_change": "nil",
"filament_retract_length": "1",
"filament_retract_length_toolchange": "nil",
"filament_retract_lift": "0.2",
"filament_retract_lift_above": "nil",
"filament_retract_lift_below": "nil",
"filament_retract_restart_extra": "nil",
"filament_retract_restart_extra_toolchange": "nil",
"filament_retract_speed": "nil",
"filament_seam_gap_distance": "nil",
"filament_settings_id": "\"PETG - Creality CR - Red\"",
"filament_shrinkage_compensation_xy": "0.33%",
"filament_shrinkage_compensation_z": "0%",
"filament_soluble": "0",
"filament_spool_weight": "0",
"filament_stamping_distance": "0",
"filament_stamping_loading_speed": "20",
"filament_toolchange_delay": "0",
"filament_travel_lift_before_obstacle": "nil",
"filament_travel_max_lift": "nil",
"filament_travel_ramping_lift": "nil",
"filament_travel_slope": "nil",
"filament_type": "PETG",
"filament_unload_time": "0",
"filament_unloading_speed": "90",
"filament_unloading_speed_start": "100",
"filament_vendor": "Generic",
"filament_wipe": "nil",
"fill_angle": "45",
"fill_density": "10%",
"fill_pattern": "gyroid",
"first_layer_acceleration": "1000",
"first_layer_acceleration_over_raft": "0",
"first_layer_bed_temperature": "85",
"first_layer_extrusion_width": "0.8",
"first_layer_height": "0.2",
"first_layer_infill_speed": "0",
"first_layer_speed": "15",
"first_layer_speed_over_raft": "30",
"first_layer_temperature": "240",
"full_fan_speed_layer": "5",
"fuzzy_skin": "none",
"fuzzy_skin_point_dist": "0.8",
"fuzzy_skin_thickness": "0.3",
"gap_fill_enabled": "1",
"gap_fill_speed": "40",
"gcode_comments": "1",
"gcode_flavor": "marlin",
"gcode_label_objects": "octoprint",
"gcode_resolution": "0.0125",
"gcode_substitutions": "",
"high_current_on_filament_swap": "0",
"host_type": "prusalink",
"idle_temperature": "nil",
"infill_acceleration": "1000",
"infill_anchor": "2.5",
"infill_anchor_max": "12",
"infill_every_layers": "1",
"infill_extruder": "1",
"infill_extrusion_width": "0.45",
"infill_first": "0",
"infill_overlap": "25%",
"infill_speed": "30",
"inherits_cummulative": "\"0.20mm QUALITY @MK3\";\"Generic PETG\";\"Original Prusa i3 MK3S & MK3S+\"",
"interface_shells": "0",
"interlocking_beam": "0",
"interlocking_beam_layer_count": "2",
"interlocking_beam_width": "0.8",
"interlocking_boundary_avoidance": "2",
"interlocking_depth": "2",
"interlocking_orientation": "22.5",
"ironing": "0",
"ironing_flowrate": "15%",
"ironing_spacing": "0.1",
"ironing_speed": "15",
"ironing_type": "top",
"layer_gcode": ";AFTER_LAYER_CHANGE\\n;[layer_z]\\n\\n@SNAPSHOT",
"layer_height": "0.2",
"machine_limits_usage": "emit_to_gcode",
"machine_max_acceleration_e": "5000,5000",
"machine_max_acceleration_extruding": "1250,1250",
"machine_max_acceleration_retracting": "1250,1250",
"machine_max_acceleration_travel": "1500,1250",
"machine_max_acceleration_x": "1000,960",
"machine_max_acceleration_y": "1000,960",
"machine_max_acceleration_z": "200,200",
"machine_max_feedrate_e": "120,120",
"machine_max_feedrate_x": "200,100",
"machine_max_feedrate_y": "200,100",
"machine_max_feedrate_z": "12,12",
"machine_max_jerk_e": "4.5,4.5",
"machine_max_jerk_x": "8,8",
"machine_max_jerk_y": "8,8",
"machine_max_jerk_z": "0.4,0.4",
"machine_min_extruding_rate": "0,0",
"machine_min_travel_rate": "0,0",
"max_fan_speed": "50",
"max_layer_height": "0.25",
"max_print_height": "210",
"max_print_speed": "200",
"max_volumetric_extrusion_rate_slope_negative": "0",
"max_volumetric_extrusion_rate_slope_positive": "0",
"max_volumetric_speed": "0",
"min_bead_width": "85%",
"min_fan_speed": "30",
"min_feature_size": "25%",
"min_layer_height": "0.07",
"min_print_speed": "15",
"min_skirt_length": "4",
"mmu_segmented_region_interlocking_depth": "0",
"mmu_segmented_region_max_width": "0",
"multimaterial_purging": "140",
"notes": "",
"nozzle_diameter": "0.4",
"nozzle_high_flow": "0",
"only_one_perimeter_first_layer": "0",
"only_retract_when_crossing_perimeters": "0",
"ooze_prevention": "0",
"output_filename_format": "{input_filename_base}_{printing_filament_types}_{print_time}.gcode",
"over_bridge_speed": "0",
"overhang_fan_speed_0": "0",
"overhang_fan_speed_1": "0",
"overhang_fan_speed_2": "0",
"overhang_fan_speed_3": "0",
"overhang_speed_0": "15",
"overhang_speed_1": "15",
"overhang_speed_2": "20",
"overhang_speed_3": "25",
"overhangs": "1",
"parking_pos_retraction": "92",
"pause_print_gcode": "M601",
"perimeter_acceleration": "800",
"perimeter_extruder": "1",
"perimeter_extrusion_width": "0.45",
"perimeter_generator": "arachne",
"perimeter_speed": "25",
"perimeters": "2",
"physical_printer_settings_id": "",
"post_process": "",
"prefer_clockwise_movements": "0",
"print_settings_id": "0.20mm QUALITY 10% infill - PETG",
"printer_model": "MK3S",
"printer_notes": "Don't remove the following keywords! These keywords are used in the \"compatible printer\" condition of the print and filament profiles to link the particular print and filament profiles to this printer profile.\\nPRINTER_VENDOR_PRUSA3D\\nPRINTER_MODEL_MK3\\n",
"printer_settings_id": "Original Prusa i3 MK3S & MK3S+",
"printer_technology": "FFF",
"printer_variant": "0.4",
"printer_vendor": "",
"raft_contact_distance": "0.1",
"raft_expansion": "1.5",
"raft_first_layer_density": "90%",
"raft_first_layer_expansion": "3",
"raft_layers": "0",
"remaining_times": "1",
"resolution": "0",
"retract_before_travel": "1",
"retract_before_wipe": "0%",
"retract_layer_change": "1",
"retract_length": "0.8",
"retract_length_toolchange": "4",
"retract_lift": "0.4",
"retract_lift_above": "0",
"retract_lift_below": "209",
"retract_restart_extra": "0",
"retract_restart_extra_toolchange": "0",
"retract_speed": "35",
"scarf_seam_entire_loop": "0",
"scarf_seam_length": "20",
"scarf_seam_max_segment_length": "1",
"scarf_seam_on_inner_perimeters": "0",
"scarf_seam_only_on_smooth": "1",
"scarf_seam_placement": "nowhere",
"scarf_seam_start_height": "0%",
"seam_gap_distance": "15%",
"seam_position": "random",
"silent_mode": "1",
"single_extruder_multi_material": "0",
"single_extruder_multi_material_priming": "0",
"skirt_distance": "1",
"skirt_height": "3",
"skirts": "1",
"slice_closing_radius": "0.049",
"slicing_mode": "regular",
"slowdown_below_layer_time": "15",
"small_perimeter_speed": "25",
"solid_infill_acceleration": "0",
"solid_infill_below_area": "0",
"solid_infill_every_layers": "0",
"solid_infill_extruder": "1",
"solid_infill_extrusion_width": "0.45",
"solid_infill_speed": "80",
"spiral_vase": "0",
"staggered_inner_seams": "0",
"standby_temperature_delta": "-5",
"start_filament_gcode": "\"{if printer_notes!~/.*(MK3.5|MINIIS).*/}\\nM900 K{if printer_notes=~/.*PRINTER_MODEL_MINI.*/ and nozzle_diameter[0]==0.6}0.12{elsif printer_notes=~/.*PRINTER_MODEL_MINI.*/ and nozzle_diameter[0]==0.8}0.06{elsif printer_notes=~/.*PRINTER_MODEL_MINI.*/}0.2{elsif nozzle_diameter[0]==0.8}0.02{elsif nozzle_diameter[0]==0.6}0.04{else}0.08{endif} ; Filament gcode LA 1.5\\n{if printer_notes=~/.*PRINTER_MODEL_MINI.*/};{elsif printer_notes=~/.*PRINTER_HAS_BOWDEN.*/}M900 K200{elsif nozzle_diameter[0]==0.6}M900 K24{elsif nozzle_diameter[0]==0.8};{else}M900 K45{endif} ; Filament gcode LA 1.0\\n{endif}\\n\\n{if printer_notes=~/.*MINIIS.*/}\\nM572 S{if nozzle_diameter[0]==0.6}0.22{elsif nozzle_diameter[0]==0.8}0.15{elsif nozzle_diameter[0]==0.4}0.36{elsif nozzle_diameter[0]==0.25}1.02{else}0{endif}\\n{endif}\\n\\n{if printer_notes=~/.*MK3.5.*/}\\nM572 S{if nozzle_diameter[0]==0.4}0.052{elsif nozzle_diameter[0]==0.5}0.042{elsif nozzle_diameter[0]==0.6}0.025{elsif nozzle_diameter[0]==0.8}0.018{elsif nozzle_diameter[0]==0.25}0.18{elsif nozzle_diameter[0]==0.3}0.1{else}0{endif} ; Filament gcode\\n{endif}\"",
"start_gcode": "M862.3 P \"[printer_model]\" ; printer model check\\nM862.1 P[nozzle_diameter] ; nozzle diameter check\\nM115 U3.14.1 ; tell printer latest fw version\\nG90 ; use absolute coordinates\\nM83 ; extruder relative mode\\nM104 S[first_layer_temperature] ; set extruder temp\\nM140 S[first_layer_bed_temperature] ; set bed temp\\nM190 S[first_layer_bed_temperature] ; wait for bed temp\\nM109 S[first_layer_temperature] ; wait for extruder temp\\nG28 W ; home all without mesh bed level\\nG80 X{first_layer_print_min[0]} Y{first_layer_print_min[1]} W{(first_layer_print_max[0]) - (first_layer_print_min[0])} H{(first_layer_print_max[1]) - (first_layer_print_min[1])} ; mesh bed levelling\\n{if filament_settings_id[initial_tool]=~/.*Prusament PA11.*/}\\nG1 Z0.3 F720\\nG1 Y-3 F1000 ; go outside print area\\nG92 E0\\nG1 X60 E9 F1000 ; intro line\\nG1 X100 E9 F1000 ; intro line\\n{else}\\nG1 Z0.2 F720\\nG1 Y-3 F1000 ; go outside print area\\nG92 E0\\nG1 X60 E9 F1000 ; intro line\\nG1 X100 E12.5 F1000 ; intro line\\n{endif}\\nG92 E0\\nM221 S{if layer_height<0.075}100{else}95{endif}\\n\\n; Don't change E values below. Excessive value can damage the printer.\\n{if print_settings_id=~/.*(DETAIL @MK3|QUALITY @MK3).*/}M907 E430 ; set extruder motor current{endif}\\n{if print_settings_id=~/.*(SPEED @MK3|DRAFT @MK3).*/}M907 E538 ; set extruder motor current{endif}",
"support_material": "1",
"support_material_angle": "0",
"support_material_auto": "0",
"support_material_bottom_contact_distance": "0",
"support_material_bottom_interface_layers": "-1",
"support_material_buildplate_only": "0",
"support_material_closing_radius": "2",
"support_material_contact_distance": "0.1",
"support_material_enforce_layers": "0",
"support_material_extruder": "0",
"support_material_extrusion_width": "0.35",
"support_material_interface_contact_loops": "0",
"support_material_interface_extruder": "0",
"support_material_interface_layers": "2",
"support_material_interface_pattern": "rectilinear",
"support_material_interface_spacing": "0.2",
"support_material_interface_speed": "80%",
"support_material_pattern": "rectilinear",
"support_material_spacing": "2",
"support_material_speed": "35",
"support_material_style": "grid",
"support_material_synchronize_layers": "0",
"support_material_threshold": "55",
"support_material_with_sheath": "0",
"support_material_xy_spacing": "50%",
"support_tree_angle": "40",
"support_tree_angle_slow": "25",
"support_tree_branch_diameter": "2",
"support_tree_branch_diameter_angle": "5",
"support_tree_branch_diameter_double_wall": "3",
"support_tree_branch_distance": "1",
"support_tree_tip_diameter": "0.8",
"support_tree_top_rate": "15%",
"temperature": "235",
"template_custom_gcode": "",
"thick_bridges": "0",
"thin_walls": "0",
"thumbnails": "160x120/PNG, 16x16/PNG, 200x200/PNG, 640x480/PNG, 800x600/PNG",
"thumbnails_format": "PNG",
"toolchange_gcode": "",
"top_fill_pattern": "monotonic",
"top_infill_extrusion_width": "0.4",
"top_one_perimeter_type": "none",
"top_solid_infill_acceleration": "0",
"top_solid_infill_speed": "25",
"top_solid_layers": "5",
"top_solid_min_thickness": "0.7",
"travel_acceleration": "0",
"travel_lift_before_obstacle": "0",
"travel_max_lift": "0",
"travel_ramping_lift": "0",
"travel_short_distance_acceleration": "0",
"travel_slope": "0",
"travel_speed": "180",
"travel_speed_z": "12",
"use_firmware_retraction": "0",
"use_relative_e_distances": "1",
"use_volumetric_e": "0",
"variable_layer_height": "1",
"wall_distribution_count": "1",
"wall_transition_angle": "10",
"wall_transition_filter_deviation": "25%",
"wall_transition_length": "100%",
"wipe": "1",
"wipe_into_infill": "0",
"wipe_into_objects": "0",
"wipe_tower": "1",
"wipe_tower_acceleration": "0",
"wipe_tower_bridging": "10",
"wipe_tower_brim_width": "2",
"wipe_tower_cone_angle": "0",
"wipe_tower_extra_flow": "100%",
"wipe_tower_extra_spacing": "100%",
"wipe_tower_extruder": "0",
"wipe_tower_no_sparse_layers": "0",
"wipe_tower_width": "60",
"wiping_volumes_matrix": "0",
"wiping_volumes_use_custom_matrix": "0",
"xy_size_compensation": "0",
"z_offset": "0"
