Why is [triger] is an invalid option for [automation]?
I suffered a corrupt microSD card in my RasberryPi so had to start afresh again. I thought I had enough notes and copy of setup files to get things running smoothly but I am getting the following error in my log and can’t work out why:
Invalid config for [automation]: [triger] is an invalid option for [automation]. Check: automation->triger. (See /home/homeassistant/.homeassistant/automation.yaml:6).
I have tried reading the documentation and feel that my script is ok and I am using the trigger option correctly.
I assume the “:6” bit means that it is my 6th automation in which case it will be the following:
 - alias: "Welcome Home"
      hide_entity: True
        platform: state
        entity_id: group.all_devices
        to: 'home'
      condition:
        condition: state
        entity_id: sun.sun
        state: below_horizon
        service: script.all_lights_on
Essentially the script should turn the lights on when one of us comes home and if it is dark.
If the :6 does not mean the 6th automation, could someone help me identify which one it is or how I can narrow it down; there are 13 automatons in total in the script.
It should be trigger with two g, not triger
6 means line number 6.
Thanks for the quick reply.
[Triger] is how the log file actually reads :slight_smile:
Line 6 is blank in my yaml file - unless it does not count # when it counts line numbers? The first 14 lines of my file are:
##Automation
- alias: "Porch Light On PM"
  hide_entity: True
    platform: sun
    event: sunset
    service: light.turn_on
    entity_id: light.front_door
That means you have written triger instead of trigger somewhere in your code.
Ha! Don’t I feel stupid - I was staring at that line for ages trying to work out what was wrong. :flushed:
The error was on line 81 though so and in ‘automation’ 8 so don’t know what the 6 meant?
Anyhow, thank you and I shall spend more time reading my code in future (I read somewhere that reading it backwards can help. Maybe I should try that!)
Great, but I do not understand why it is not on line 6.
Hi @johngc,
Yesterday i updated HA from 0.45.1 to 0.50.2 and i had some errors in my configuration:
imagen
One of the errors (automation one) is more or less the same than yours:
here the log:
2017-08-22 23:25:23 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: [after] is an invalid option for [automation]. Check: automation->trigger->1->after. (See /config/configuration.yaml, line 102). Please check the docs at https://home-assistant.io/components/automation/
How did you find exacly the error? you were looking one by one each automation?
thanks
