I have one setup at home and one at my cabin. The one at my cabin has been updated gradually to the latest version, while the one at home is a totally new install. On the new install the zwcfg_*.xml file hasn’t been changed since I copied it from the previous install, and I don’t know if it’s using it at all. I see the correct settings for the devices (Heat it! Z-Wave thermostats needed an XML setup to work correctly), but that may be from a newer version of the config file in /srv/homeassistant/lib/python3.5/site-packages/python_openzwave/ozw_config.
Now that I have added an ID Lock securely, it is not showing in the zwcfg file, and the file hasn’t been changed since the 21st of October, with a permission change on the 25th of october. How do I get the system to use that again?
