I’ve got a new RBP3 installation configured from HASSbian. My zwave configuration must be OK because when I add a Vision Alarm Siren, I can see it on HA. However, I’ve added the Sensative sensor but it doesn’t appear. I’ve tried resetting the Zwave stick, starting with a clean slate by deleting zcfg*, pyozw* and OZW*. After adding the Sensative sensor by pressing the button on a unplugged zstick, my zwcfg* file after reboot is:
<?xml version="1.0" encoding="utf-8" ?>
Can someone explain why Sensative doesn’t appear? I’m not able to get the open-zwave config panel to compile yet, but I have the zensys tools. Any ideas would be appreciated.
Ok, not sure why my config file didn’t appear but I sorted out the problem. I was able to compile the zwave control panel and then copy the *xml file to my HA directory. All is well.
vibrog
(Vidar Gundersen)
February 17, 2017, 12:59pm
3
Can you be more specific about what you did?
Did you replace the HA zwcfg-*.xml
file with the one created using OZCP?
Tinkerer
(aka DubhAd on GitHub)
February 17, 2017, 2:12pm
4
Should be no need for that. When I added my Sensative strip under 0.36 I just went through the standard inclusion process. If you’re having problems, it’ll be worth providing some details.
vibrog
(Vidar Gundersen)
February 17, 2017, 2:41pm
5
I’m using HA 0.38.3, python-openzwave 0.32 (now and when including).
The Sensative Strip does not appear in the entity list under the developer tools panel.
They were added to zwcfg-*.xml
, but without manufacturer/product name or command class value lists properly populated when compared to https://github.com/OpenZWave/open-zwave/blob/master/config/sensative/strips.xml .
I can see communication from the Sensative Strip in OZW_Log.txt
So it seems it is properly treated by open-zwave, but not HA?
Tinkerer
February 17, 2017, 3:45pm
6
Well, HA is underpinned by OZW, so that’s not the problem.
Mine added correctly, and the entry in my ozwcfg is quite long. How did you install HA?
After you have added the strips in OZWCP, save the configuration and exit OZWCP. Then copy the zwcfg_*.xml file from the OZWCP directory to your HA installation. My HA installation is located at /home/homeassistant/.homeassisant. Restart HA and your new zwave devices should appear in the list of entities.
vibrog
(Vidar Gundersen)
February 18, 2017, 10:50am
8
I installed HA using pip3 install homeassistant
, and manually built OZW.
Could you post the Sensative Strip part of your zwcfg_*.xml
(I’m struggling a bit compiling OZWCP from source om macOS.)
Tinkerer
February 18, 2017, 12:44pm
9
Here it is:
<Node id="10" name="" location="" basic="4" generic="7" specific="1" roletype="6" devicetype="3079" nodetype="0" type="Notification Sensor" listening="false" frequentListening="false" beaming="true" routing="true" max_baud_rate="40000" version="4" query_stage="Complete">
<Manufacturer id="19a" name="Sensative">
<Product type="3" id="3" name="Strips" />
</Manufacturer>
<CommandClasses>
<CommandClass id="32" name="COMMAND_CLASS_BASIC" version="1" request_flags="4">
<Instance index="1" />
<Value type="byte" genre="basic" instance="1" index="0" label="Basic" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
</CommandClass>
<CommandClass id="48" name="COMMAND_CLASS_SENSOR_BINARY" version="1" request_flags="4" innif="true">
<Value type="bool" genre="user" instance="1" index="0" label="Sensor" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="False" />
<SensorMap index="0" type="55" />
<SensorMap index="0" type="200" />
</CommandClass>
<CommandClass id="90" name="COMMAND_CLASS_DEVICE_RESET_LOCALLY" version="1" request_flags="4" innif="true">
</CommandClass>
<CommandClass id="94" name="COMMAND_CLASS_ZWAVE_PLUS_INFO" version="1" request_flags="4" innif="true">
<Value type="byte" genre="system" instance="1" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="1" />
<Value type="short" genre="system" instance="1" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="3079" />
<Value type="short" genre="system" instance="1" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="3079" />
</CommandClass>
<CommandClass id="112" name="COMMAND_CLASS_CONFIGURATION" version="1" request_flags="4" innif="true">
<Value type="list" genre="config" instance="1" index="1" label="Notification type" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="1" size="1">
<Help>Set Notification type.</Help>
<Item label="Binary Sensor report" value="0" />
<Item label="Notification report" value="1" />
<Item label="Basic report" value="2" />
</Value>
<Value type="list" genre="config" instance="1" index="2" label="Led indication" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="1" size="1">
<Help>Set Led indication.</Help>
<Item label="Off" value="0" />
<Item label="On" value="1" />
</Value>
</CommandClass>
<CommandClass id="113" name="COMMAND_CLASS_ALARM" version="4" request_flags="2" innif="true">
<Value type="byte" genre="user" instance="1" index="0" label="Alarm Type" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="byte" genre="user" instance="1" index="1" label="Alarm Level" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="byte" genre="user" instance="1" index="2" label="SourceNodeId" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="byte" genre="user" instance="1" index="9" label="Access Control" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="254" />
<Value type="byte" genre="user" instance="1" index="10" label="Burglar" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="254" />
</CommandClass>
<CommandClass id="114" name="COMMAND_CLASS_MANUFACTURER_SPECIFIC" version="1" request_flags="4" innif="true">
</CommandClass>
<CommandClass id="115" name="COMMAND_CLASS_POWERLEVEL" version="1" request_flags="4" innif="true">
<Value type="list" genre="system" instance="1" index="0" label="Powerlevel" units="dB" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
<Item label="Normal" value="0" />
<Item label="-1dB" value="1" />
<Item label="-2dB" value="2" />
<Item label="-3dB" value="3" />
<Item label="-4dB" value="4" />
<Item label="-5dB" value="5" />
<Item label="-6dB" value="6" />
<Item label="-7dB" value="7" />
<Item label="-8dB" value="8" />
<Item label="-9dB" value="9" />
</Value>
<Value type="byte" genre="system" instance="1" index="1" label="Timeout" units="seconds" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="button" genre="system" instance="1" index="2" label="Set Powerlevel" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
<Value type="byte" genre="system" instance="1" index="3" label="Test Node" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="list" genre="system" instance="1" index="4" label="Test Powerlevel" units="dB" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
</Value>
<Value type="short" genre="system" instance="1" index="5" label="Frame Count" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
<Value type="button" genre="system" instance="1" index="6" label="Test" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
<Value type="button" genre="system" instance="1" index="7" label="Report" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
<Value type="list" genre="system" instance="1" index="8" label="Test Status" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
<Item label="Failed" value="0" />
<Item label="Success" value="1" />
<Item label="In Progress" value="2" />
</Value>
<Value type="short" genre="system" instance="1" index="9" label="Acked Frames" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
</CommandClass>
<CommandClass id="128" name="COMMAND_CLASS_BATTERY" version="1" request_flags="4" innif="true">
<Value type="byte" genre="user" instance="1" index="0" label="Battery Level" units="%" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="100" />
</CommandClass>
<CommandClass id="132" name="COMMAND_CLASS_WAKE_UP" version="2" request_flags="2" innif="true">
<Value type="int" genre="system" instance="1" index="0" label="Wake-up Interval" units="Seconds" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="86400" />
<Value type="int" genre="system" instance="1" index="1" label="Minimum Wake-up Interval" units="Seconds" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="1800" />
<Value type="int" genre="system" instance="1" index="2" label="Maximum Wake-up Interval" units="Seconds" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="86400" />
<Value type="int" genre="system" instance="1" index="3" label="Default Wake-up Interval" units="Seconds" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="86400" />
<Value type="int" genre="system" instance="1" index="4" label="Wake-up Interval Step" units="Seconds" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="60" />
</CommandClass>
<CommandClass id="133" name="COMMAND_CLASS_ASSOCIATION" version="1" request_flags="4" innif="true">
<Associations num_groups="1">
<Group index="1" max_associations="1" label="Lifeline" auto="true">
<Node id="1" />
</Group>
</Associations>
</CommandClass>
<CommandClass id="134" name="COMMAND_CLASS_VERSION" version="1" request_flags="4" innif="true">
<Value type="string" genre="system" instance="1" index="0" label="Library Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="6" />
<Value type="string" genre="system" instance="1" index="1" label="Protocol Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="4.05" />
<Value type="string" genre="system" instance="1" index="2" label="Application Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.05" />
</CommandClass>
</CommandClasses>
</Node>
vibrog
(Vidar Gundersen)
February 19, 2017, 2:50pm
10
Thanks! Using this, the sensors came up in HA.
vibrog
(Vidar Gundersen)
February 20, 2017, 8:18am
11
Is it correct that binary_sensor.sensative_strips_sensor_*_0
is not reporting on/off (open/closed), whereas sensor.sensative_strips_access_control_*_9
is reporting 22 (=open)/23 (=closed)? Have you created a template binary_sensor to use it for open/close? How have you used the Sensative Strips in your HA configuration?
Here’s my sensor. I found that the sensative strips sometimes report 255. Never got a good answer from the company on why they report 255. So here’s my workaround.
friendly_name: Family Room Door
value_template: >-
{% if is_state("sensor.doorsensor_access_control_16_9", "22") %}
open
{% else %}
closed
{% endif %}
Tinkerer
February 20, 2017, 7:23pm
13
Like many Z Wave devices, they come in Basic mode by default. You’ll need to switch them to Binary to get the binary device operating. You do that by waking them up, then setting parameter 112 to 0 (it’s more obvious to do using ozwcp
, but it’s just as achievable using the HA dashboard).
Alternatively, @homehacker ’s solution works if you leave it in basic mode - that’s how I left it for my initial setup.
I think I might have also left them in Basic mode so I can query the sensors and get their battery status.
Tinkerer
February 20, 2017, 8:37pm
15
Binary mode still reports the battery level for me:
battery_level: 100
vibrog
(Vidar Gundersen)
February 21, 2017, 5:08pm
16
I’m using your above example with a binary sensor value template, but it only displays as ‘off’, however using the templates developer tool it displays the expected string.
Here’s the exact entry in my sensors.yaml file.
sensors:
door_16:
value_template: >-
open
{% else %}
closed
{% endif %}
Also, if you look in the developer’s “states” window, you should see (in my case), sensor_door_16 closed.
vibrog
(Vidar Gundersen)
February 23, 2017, 7:30am
18
As sensor
or binary_sensor
As binary_sensor.doorsensor_sensor_16_0
vibrog
(Vidar Gundersen)
February 24, 2017, 7:35am
20
I had to do it this way:
sensor: # binary_sensor did not work
sensors:
door_entrance:
value_template: >
{% if is_state("sensor.sensative_strips_access_control_13_9", "22") %}
open
{% else %}
closed
{% endif %}
