Xmoncoco
(Hadjadji Milhan)
1
hello I try several times to create a command line sensor with javascript. this is the command-line.yaml who as is own call on the configuration. yaml
- sensor:
command: ./config/script/ednote.sh
unique_id: "sjflevjifdsqfklfdlfjdljqshflhfdqjskfharjkghjqkrfghqsjklghqsslkfjdhgkjlqfhgjk"
value_template: '{{ value.moyenneGenerale }}'
and the js file is at the right place and sh file so I hope someone whould help me
VDRainer
2
Does your command work in a terminal?
Read here how you can test it in the HA container if you’re using HAOS.
Xmoncoco
(Hadjadji Milhan)
3
yes of course I use it in cmd with to interpreters (bun and node either work)
VDRainer
4
Why the point at the beginning?
The config folder lives in root /
