I’m a newby with Home Assistant and spend many hours/days figuring out why my LimiteLess LED configuration was giving no response at all. Read many/all items I could find in the community and on the internet but none solved the issue for me. I think I figured it out and wanted to share it for people having similar issue.
As far as I’ve seen this has not been reported and if so unfortunately missed it. I figured it out after tracing the traffic of the milight 3.0 app on a rooted phone and I did not see 0x80 0x00 0x00 0x00 0x11 in the preamble. But saw 0x83 0xpp 0xpp 0x00 0x11. And the pppp was my pin code I typed in years ago. I was not aware anymore there was a pin code. The default is indeed 0000. I changed the pin code in the iBox2 using the milight app but nothing happened. I could not figure this out but I assume a core restart does not harm. As it it is working now as it should. Changing the pin code something else then 0000 even makes it reproducible.
So just because I was not aware of the pincode between the iBox2 and MiLight3 app also never figured that could be an issue.
For me it solved the issue with a very simple/fast workaround but there were moments I thought why bother it just does not work.
Workaround: Set pin code back to default 0000 (probably a factory reset will do as well)
Open milight 3 app
Slide left on the iBox2
change password
Enter old password (hope you have it)
Set new to 0000
The rest in HA as suggested, default version 6, default port 5987 (verify iBox2: UDP/5987)
And then there finally was light in the dark
I’m not aware the pincode/password can be configured in HA as in theory there should/could be an configuration item (improvement) (under host).
Keep up the great work!
