Why my switches are in unused entities and not in home page?
hello dear friends
I used esp8266 to make switches in home assistant and I will show you the configration.yaml file if you could understand anything about what is wrong with it, please help.
homeassistant:
Name of the location where Home Assistant is running
Location required to calculate the time the sun rises and sets
latitude: 36.1833
longitude: 44.0119
Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 0
metric for Metric, imperial for Imperial
unit_system: metric
Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: Asia/Baghdad
Customization file
customize: !include customize.yaml
Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
base_url: example.duckdns.org:8123
Discover some devices automatically
discovery:
mqtt:
broker: 192.168.xx.xx
port: 1883
client_id: home-assistant-1
keepalive: 60
username: xxxxx
password: xxxx
protocol: 3.1
switch 1:
  • platform: mqtt
    name: “MQTT Switch 1”
    state_topic: “/house/switchConfirm1/”
    command_topic: “/house/switch1/”
    payload_on: “1”
    payload_off: “0”
    qos: 0
    retain: true
switch 2:
  • platform: mqtt
    name: “MQTT Switch 2”
    state_topic: “/house/switchConfirm2/”
    command_topic: “/house/switch2/”
    payload_on: “1”
    payload_off: “0”
    qos: 0
    retain: true
switch 3:
  • platform: mqtt
    name: “MQTT Switch 3”
    state_topic: “/house/switchConfirm3/”
    command_topic: “/house/switch3/”
    payload_on: “1”
    payload_off: “0”
    qos: 0
    retain: true
switch 4:
  • platform: mqtt
    name: “MQTT Switch 4”
    state_topic: “/house/switchConfirm4/”
    command_topic: “/house/switch4/”
    payload_on: “1”
    payload_off: “0”
    qos: 0
    retain: true
Sensors
Weather prediction
  • platform: yr
Text to speech
tts:
  • platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
First, you should format your code. Take a look at the posting guide here to learn how to do that, it’s covered under number 11:
Unused entities is a list of entities that you haven’t included in your frontend yet.
If you want to include them in your frontend, add them wherever you want.
