Why Shelly components can not be auto-discovered by Home Assistant
Why Shelly components can not be auto-discovered by Home Assistant.
Also when I use “ADD INTEGRATION” button to put shally Display, Home assistant askes for “Host” and “Port”, in this case Which Port should be mentioned here?
In order to auto discover devices the devices need to announce their presence on the network. Not all devices do so.
Most Shelly devices are discovered.
The default port is 80 unless you have changed it on the device. It tells you that in the dialogue box.
If you get this dialogue, you put security on the internal Shelly device page (which you should do). These credentials are the one you used for that.
If Shelly devices do announce themself, then it suggests an incorrect network setup. Not inside HA though, but the actual design and configuration of the network.
Thank you for your reply.
I am a new beginner in Home assistant word, I actually have 6 different Shelly devices, but none of them discovered by Home assistant automatically. Still I can not connect Shelly devices to Home assistant.
I see all of my Shelly devices on my router. With MAC & IP addresses But I can not see the Port numbers.
Where in Shelly devices you can define Port number?
Have you read and completed the steps on this page for all your shelly devices?
I tried this with my Home assistant IP. But no luk.
I have a “Home Assistant Yellow KIT” which is connected to the Network via a RJ45 cable. But Shelly display uses WIFI, both of them are in a same home network.
Could it be a problem?
No, they are supposed to be on the same network. That’s the same setup I have.
You’re sure you have Gen2 or Gen 3 devices and not Gen 1?
Some access points/routers have WiFi segregation enabled as default, so WiFi devices can not see each other and multicast does often not work, which affect auto discovery.
