Why Sonoff disappeared from HA
I apologize for my English, I am from Ukraine.
prompt in which folder you need to install the “custom_components” folder
and of course the component itself is SonoffLAN.
For some reason he disappeared from the store?
on my Debian 11, Doker, Home Assistant,
krskrab,
why sonoff support disappeared in HA, you know ?
this is the main question …
I will certainly watch this video, thanks …
but I don’t quite understand English colloquially, but still, thanks friend.
this is all very good, but …
I do not see any Sonoff add-ons in the modern panel
in http://192.168.1.12:8123/hassio/store
maybe I’m not looking for it there?
sorry, I haven’t created an account with evelink yet, and I don’t have a username or password …
but i want to connect 2 devices first …
first I want to see them in HA, or see support for these devices first …
you can give me a link to go to this page in
You are using SonoffLAN by AlexxIT, which is installed via HACS, yes?
If yes, and assume you install everything correctly, you would NOT find any SonoffLAN integration anywhere under Configuration > Integration like this:
And this is because that specific Integration is not configured via GUI. You would have to setup everything in your configuration.yaml
Reference the video (see above) and the GitHub manual (also see above).
Hello, Dear Home Assistant specialists!
I want to wish you a Happy New Year!
I want to strongly apologize for my pause,
she was connected with technical problems …
But, 12/31/2021: 22; 30 I had doubts -
How can a Wi-Fi device be able to access the network if it doesn’t know the password?
And just by logic, I realized that the only way to tell the Wi-Fi chip of the Sonoff device is the password,
it is to tell him the password by connecting through the eWeLink application …
This time, I basically did NOT reflash the ESP, I just wanted to check Home Assistant for the ability to find Sonoff devices myself.
And also it was necessary to register the eWeLink account data in the Home Assistant configuration file.
After registering with eWeLink, the app successfully found my 2 Sonoff devices and then Home Assistant found them.
Thank you all for your help.
