This seems obvious, if you’re going to move a core component from YAML configuration to UI configuration, there should be a way to set all the properties of that integration.
Is there some assumption that if you’re using the UI that all of your devices are magically compliant with the latest z-wave properties?
If I want to go back to YAML configuration, how do i retrieve my network key?
Just for your information, the current Z-Wave integration is going to be deprecated and replaced by OZW Daemon.
I’m aware, but that still doesn’t work on my setup last i checked (I should try it again now that i have re-paired all my devices)
Also I need my network key to switch to a new system, but I can’t find it anywhere.
Maybe it’s stored somewhere in the .storage files.
ronytomen
(Tony)
September 2, 2020, 12:25am
6
I was only able to set this by setting zwave
in the YAML configuration file.
ronytomen
(Tony)
September 2, 2020, 12:43am
7
Yes, the .storage
contains that information, specifically the .storage/core.config_entries
file.
Search for "domain": "zwave"
in the file, there you will find data like this:
"connection_class": "local_push",
"data": {
"network_key": "0x4E, 0x6F, 0x20, 0x6D, 0x6F, 0x72, 0x65, 0x20, 0x73, 0x65, 0x63, 0x72, 0x65, 0x74, 0x73, 0x21",
"usb_path": "/dev/ttyACM0"
"domain": "zwave",
"entry_id": "596f7520746f6f6b207468652074696d653f",
"options": {},
"source": "import",
"system_options": {
"disable_new_entities": false
"title": "Z-Wave",
"unique_id": null,
"version": 1
Thanks, I didn’t think to check that file.
Unfortunately the new integration still crashes with Kwikset locks, so still a no-go for me
