Why the Heck can't I just use Google maps as a card?
Right now we either have to use open street map, or use the workaround that requests images of google maps as a picture card.
So why the heck can’t Home Assistant just have a Google Maps integration/card?
I believe this is the appropriate API, https://developers.google.com/maps/documentation/javascript/geolocation
Edit: I know you can embed it as an iframe, but that is no good for geolocation sensors (yeah i know i should’ve specified before), the idea is i want to see the location of a person over layed on Google maps.
I think the problem with that is the requirement for an API key. I know there are integrations which require API keys but, as far as I know, there are no cards that require this.
Actually, you can use Google Maps with an iframe card.
You must have a Google Maps API key and load a local html page with the appropriate code.
Here’s an example of my implementation:
I mostly display this card on a morning routine just to check the current traffic in my city.
If you’re interested in the html code, let me know!
I’d be interested in the entire config for this page. I like the organization and compactness and I’m starting on a similar page myself.
i know you can do that, i just meant for device trackers, so for example if i want to see my dads location, i have to either have a zone for that location, or figure out “what is on x road?”
@tboyce1 This is actually my “developping” page, where I test different card configurations.
However, the majority of my lovelace configuration is based on the same design, so here’s for example the ‘NAS’ Card configuration so you can get a general idea.
 type: entities
 entities:
      - type: 'custom:multiple-entity-row'
        entities:
          - entity: sensor.nas_cpu_load_total
          - entity: sensor.nas_memory_usage_real
          - icon: 'mdi:dots-vertical'
            tap_action:
              action: url
              url_path: 'http://192.168.*.*'
        entity: binary_sensor.nas_security_status
        icon: 'mdi:nas'
        secondary_info:
        show_state: false
      - entities:
          - entity: sensor.nas_network_down
          - entity: sensor.nas_network_up
        icon: ' '
        show_state: false
        tap_action:
          action: none
      - style:
          background-color: black
          height: 1px
        type: divider
      - entities:
          - entity: sensor.nas_drive_1_temperature
          - entity: sensor.nas_volume_1_used_space
          - entity: sensor.nas_volume_1_volume_used
        entity: sensor.nas_drive_1_status
        icon: 'mdi:harddisk'
        secondary_info:
        show_state: false
      - entities:
          - entity: binary_sensor.nas_drive_1_below_min_remaining_life
          - entity: binary_sensor.nas_drive_1_exceeded_max_bad_sectors
        show_state: false
      - style:
          height: 1px
        type: divider
      - entities:
        group: true
        hours_to_show: 4
        line_width: 3
        points_per_hour: 5
        show:
          icon: false
          labels: true
          state: false
        type: 'custom:mini-graph-card'
Does the map auto-refresh, or do you have to manually refresh? If you have worked out a way to auto-refresh, LOTS of people (myself included) would be interested in details on how you are doing it.
If you install the HomeAssistant app on his phone, there’s a geocode sensor that’s available with the device tracker.
I know, but as far as i am aware, all I can do is either view his location from the sensor history, or have it displayed in a map card. My request is an option to use Google Maps instead of Open Street Map. I know the Ariela app does it.
And I was replying to your last post, not the overall thread :wink:
If you expand a response with the little reply arrow, you can see who a person was responding to.
When you refresh Lovelace the map will certainly refresh as well and fetch the latest info.
I have also noticed that the traffic layer is dynamically updated without having to refresh Lovelace.
However, I cannot be 100% sure for the latter, since I only use this card as a popup on my DIY Frame, each morning before leaving for work.
A Lovelace refresh will certainly refresh the map.
*edit: You can of course drag and scroll on the map as expected. I mean it is not a static image.
