As long as the implementation limits included entities to ones that were created before the start event (of when you reload groups), this could work. Otherwise you would have to watch all states and add new entities to the group when they appear which could get a bit expensive if you have a lot of groups that need this.
Iām not sure if that limitation would still make this useful
I see you stopped working on the feature though, is that because you think it might not be merged? I think what @frenck talked about the group.all_* are quite different TBH (maybe similar internally but very different for the user).
Iām waiting for more information on the history related to the removal of all the automatic groups and the reasoning behind it. Also, if we think its going to be necessary to implement functionality to automatically update the groups when entities are added and removed, I will switch gears and working on adding a performant way to track entities being removed (we already have a performant way to track new ones being added).
I can understand why group.all_whatever was eliminated. Frankly, I never used the āallā groups so they represented some needless overhead for me; I got something I didnāt use and couldnāt get rid of it.
However, they were useful for other people so, very quickly, a workaround was devised: an automation triggered at startup that creates the desired group from scratch (be it all lights, or all temperature sensors, or whatever). A template is employed to select the desired entities and add them to a group. Easy-peasy workaround for anyone willing to take the time to create the automations.
Whatās proposed here is just a simplified version of what the workaround does. The people reviewing this proposal shouldnāt be comparing it to the deprecated āallā groups (which were created even if you didnāt use them). This proposal still requires users to define the groups they want, just more easily than by creating an automation.
In a nutshell, this proposal is a simplification of an existing workaround and has nothing to do with deprecated āallā groups.
