lpt2007
(lpt2007)
1
My config:
menu_heat_cool:
view: yes
name: ogrevanje & hlajenje
control: hidden
entities:
- group.mqtt_hallway_climate
mqtt_hallway_climate:
control: hidden
entities:
- climate.melcloud_hodnik_klima_120984
- sensor.mqtt_hallway_climate_today
- sensor.mqtt_hallway_climate_yesterday
- sensor.mqtt_hallway_climate_total
- switch.sonoff_pow_02
- sensor.mqtt_hallway_climate_sensor_tem_outside_unite
- sensor.mqtt_hallway_climate_sensor_hum_outside_unite
tom_l
2
Could you please rephrase your question with a bit more detail?
I’m not certain what you are asking.
lpt2007
(lpt2007)
3
Hi @tom_l
I asked why all items in the group not in one line?
Like this:
finity
4
It looks like you have configured the group’s as if you are using the old states ui.
Is that correct or are you using Lovelace as the ui?
tom_l
6
Then use a vertical stack card to group an entities card and a climate card.
finity
7
Since you are using lovelace the the first group where you defined it as a view has absolutely no use. You can delete it.
And you can also probably delete the second group too since it isn’t being used anywhere.
then use the cards that @tom_l suggested above to group you entities together as you want.
lpt2007
(lpt2007)
8
Hi @finity, can you show me an example base on my configuration.
finity
9
something like this maybe:
- type: vertical-stack
cards:
- type: thermostat
entities:
- type: entities
entities:
lpt2007
(lpt2007)
10
Ok, in lovelace is better to use cards not group for organization?
lpt2007
(lpt2007)
11
Why I can use vertical and horizontal stack card?
my configuration;
- title: Hlajenje & Ogrevanje
path: heat_cool
cards:
- type: thermostat
entity: climate.melcloud_hodnik_klima_120984
- type: entities
entities:
- type: horizontal-stack
cards:
- type: gauge
entity: sensor.mqtt_hallway_climate_sensor_tem_outside_unite
min: -50
max: +50
severity:
green: -50
yellow: 24
red: 35
- type: gauge
entity: sensor.mqtt_hallway_climate_sensor_hum_outside_unite
severity:
green: 0
yellow: 30
red: 45
I would like to have like this:
lpt2007
(lpt2007)
12
This probably related to web page height? If this is a problem how to prevent cards to auto move to new column on page height change?
