Hi. I’m hoping someone could look at my config and tell me if I’ve missed something?
Basically, I have 2 switches (One Sonoff Mini & one Sonoff Basic). All I want to do is to be able to switch either one of them from the Overview page, which seems simple enough. But if I’m honest, I seem to be struggling.
Heres my config
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: example.duckdns.org:8123
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
mqtt:
broker: 192.168.1.91
port: 1883
username: "Ydraiggoch"
password: "Password"
switch:
- platform: mqtt
command_topic: "cmd/sonoff01/power"
state_topic: "stat/sonoff01/POWER"
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: true
- platform: mqtt
command_topic: "cmd/sonoff02/power"
state_topic: "stat/sonoff02/POWER"
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: true
I have the switches visible on the Overview page;
But when I try to switch one of them on, it toggles on for about 5 seconds before turning off again automatically.
I suspect this is something to do with the MQTT, but not sure what.
I have the Mosquitto Add On installed and each sonoff is connected (according to the Log & Console in Tasmota.
Here is a snip from the MQTT Log;
1575211104: New connection from 192.168.1.86 on port 1883.
[INFO] found Ydraiggoch on local database
1575211105: New client connected from 192.168.1.86 as DVES_A76427 (p2, c1, k30, u’Ydraiggoch’).
1575211334: Saving in-memory database to /data/mosquitto.db.
1575213135: Saving in-memory database to /data/mosquitto.db.
1575214936: Saving in-memory database to /data/mosquitto.db.
1575216737: Saving in-memory database to /data/mosquitto.db.
1575218538: Saving in-memory database to /data/mosquitto.db.
1575220339: Saving in-memory database to /data/mosquitto.db.
1575222140: Saving in-memory database to /data/mosquitto.db.
1575223941: Saving in-memory database to /data/mosquitto.db.
1575225742: Saving in-memory database to /data/mosquitto.db.
1575227543: Saving in-memory database to /data/mosquitto.db.
1575229344: Saving in-memory database to /data/mosquitto.db.
1575231145: Saving in-memory database to /data/mosquitto.db.
1575232647: Client auto-6265ECCA-A22F-9C79-5C11-D775021797B9 disconnected.
1575232668: New connection from 192.168.1.91 on port 1883.
1575232669: New client connected from 192.168.1.91 as auto-FBF6F6AA-DA5F-52A9-B2CF-4A719AB40635 (p2, c1, k60, u’Ydraiggoch’).
1575232946: Saving in-memory database to /data/mosquitto.db.
191.168.1.86 is one of the switches and 191.168.1.91 is the Home Assistant (Py) and MQTT
Could this have anything to do with both the MQTT and HAS starting at the same time (on the same IP address?
Thanks for any suggestions
