Some Home Assistant users reported that their Matter WiFi switches occasionally become unavailable.
First, it is important to understand that the Matter protocol itself is not the problem. Matter defines how devices communicate with smart home platforms, but WiFi devices still depend on your local WiFi network, router stability, and network configuration.
Here are some common causes and solutions.
Why Matter WiFi Devices May Go Offline
1. WiFi Network Stability
Smart switches are usually installed inside walls, where the WiFi signal may not be as strong as other devices.
Possible causes:
- Weak 2.4GHz signal
- Router coverage issues
- WiFi interference
- Too many devices connected to the same network
Recommended:
- Check WiFi signal strength near the switch
- Use a stable 2.4GHz IoT network
- Improve WiFi coverage if needed
2. Router and Network Settings
Some routers may disconnect IoT devices due to optimization features.
Check:
- DHCP lease settings
- Automatic channel switching
- Band steering between 2.4GHz and 5GHz
- Firewall or multicast settings
A stable local network is important for any smart home system.
Already Have Many Matter WiFi Devices?
If you already have several Matter WiFi devices and some of them are installed far away from your main router, the WiFi connection quality may become the main challenge.
In this situation, using a gateway can be a practical solution.
With the Zemismart M1 gateway, Matter WiFi devices can be added through the Tuya ecosystem and then shared back to Matter platforms.
This setup can help when:
- WiFi coverage is not strong enough in certain areas
- You have many smart devices increasing the load on your WiFi network
The gateway acts as a centralized connection point, making device management easier and reducing the need for every device to maintain a direct connection to your main WiFi network.
However, if your WiFi signal is already strong and stable, a gateway may not be necessary.
→ Zigbee switches, sensors, motors, and other devices
For New Smart Home Installations
For users who are building a new smart home system, we generally recommend:
Gateway + Zigbee Devices
A Zigbee-based system is still one of the most stable solutions for large smart homes.
Advantages:
- Dedicated low-power mesh network
- Devices communicate through Zigbee routers
- Less load on your WiFi network
- Mature ecosystem with Home Assistant support (ZHA / Zigbee2MQTT)
A typical setup:
Home Assistant
→ Zigbee Gateway
Summary
Existing Matter WiFi users:
Optimize WiFi network
Consider using a gateway solution for centralized management
New smart home projects:
Zigbee + Gateway remains a very stable choice
Matter over Thread will provide another reliable option soon
Choosing the right wireless technology is just as important as choosing the smart device itself.
