Hi everyone!
I am looking for a Wi-Fi Temperature & Humidity sensor that I need to place into a sauna.
For this reason it needs to have two main features:
- the sensor should be placed on an extension cord as the main unit should be mounted outside the sauna
- its temperature upper threshold should be 95-100 degrees (it is a Finnish sauna)
Obviously, I need to connect it with Home Assistant
Thank you very much!
Bye
