Hi everyone,
I’m trying to create a sensor to use in Energy Configuration.
I use the code from hass_wibeee
Past the code to yaml config file
I’m only getting values from the first sensor (sensor.grid_import_export_power)
From the other two I’m only get “unavailable”
I need some help and forgiven for the noob question
sensors:
# Power sensors (W) #
grid_import_export_power:
friendly_name: "Grid import(+) or export(-) power"
device_class: power
unit_of_measurement: 'W'
value_template: >-
{% if states('sensor.wibeee_001ec03278d0_power_factor_l3') | float < 0 %}
{{ states('sensor.wibeee_001ec03278d0_active_power_l3') | float * -1 | round(0) }}
{% else %}
{{ states('sensor.wibeee_001ec03278d0_active_power_l3') | float | round(0) }}
{% endif %}
grid_import_power:
friendly_name: "Grid import power"
device_class: power
value_template: "{{ states('sensor.grid_import_export_power') | float | max(0) | round(0) }}"
grid_export_power:
friendly_name: "Grid export power"
device_class: power
value_template: "{{ states('sensor.grid_import_export_power') | float | min(0) | abs | round(0) }}"
