Widget Position
Hi happy people… I am new to lovelace. I wanna build a nice dashboard (also for the WAF) it has to be clean and intuitive. BUT I am failing directly in organizing the widgets. Just a small example attached. I want cam left and weather right. But it is set automatically by home assistant. Could someone help me out with this?
You can use the layout-card, or, what i do on some views to build a gap, the gap-card.
Would you mind posting an example how to make this in this case?
I use custom cards
what about using the “horizontal-stack” card
The problem is the proportions don’t fit my needs …means a picture-glance card with my live feed for my cam will be small and beside my custom radial card will use too much space …I might be wrong but I never got the result I wanted
@VDRainer
type: 'custom:layout-card'
cards:
  - type: weather-forecast
    entity: weather.chauconin_neufmontiers
  - type: picture-glance
    title: Front House
    entities: []
    camera_image: camera.front_door
    camera_view: live
    style: |
      ha-card {
        background: none;
        box-shadow: none;
        color: white;
so far i have this:
But I am now missing to use custom css for the frame of the cam and the weather like here:
And here is where I am stuck
Here is how I configured the cam card for example:
Sorry, but i’m a complete CSS noob.
You dont have your styles defined in the code above, maybe that’s the problem?
The are multiple examples on the layout-card git.
Also one for setting the column_width. Maybe give it a try.
