Wiegand Keypad and MH-ET ESP32 Dev
Hi All –
I wanted to connect a Wiegand reader from Hikvision (DS-K1802MK) to a MH-ET ESP32 Dev Kit Board, however I am unsure to which GPIOs I should connect the D0 and D1 from the Reader. Here’s the code below but I receive nothing when it’s all connected.
esphome:
  friendly_name: wiegand-keypad
  platform: ESP32
  board: mhetesp32devkit
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "xxxxxxxxxx"
ota:
  - platform: esphome
    password: "xxxxxxxxxx"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Wiegand-Keypad Fallback Hotspot"
captive_portal:
wiegand:
  - id: reader
    d0: GPIO25
    d1: GPIO26
    on_key:
            - lambda: ESP_LOGI("KEY", "received key %d", x);
    on_tag:
            - lambda: ESP_LOGI("TAG", "received tag %s", x.c_str());
    on_raw:
            - lambda: ESP_LOGI("RAW", "received raw %d bits, value %llx", bits, value);
I have one connected on WT32-ETH01 board and it works very good.
If my code can help you, here it is.
# wgtgrdr1.yaml
# Wiegand RFID čitač namijenjen za garažu
# radi s 13.56 MHz i 125khz wiegand čitaćem
# Detaljniji opis u readme.txt
globals:
  - id: led_status
    type: int
    restore_value: no
    initial_value: '0'
  - id: reboot_counter
    type: int
    restore_value: no
    initial_value: '0'
  - id: api_was_connected
    type: int
    restore_value: no
    initial_value: '0'
  - id: buzzer_status
    type: int
    restore_value: no
    initial_value: '0'
  - id: kHz125
    type: bool
    restore_value: false
    initial_value: "false"
  - id: tag_ena
    type: bool
    initial_value: "true"
  - id: hass_init_executed_state
    type: bool
  - id: sound_ena
    type: bool
  - id: heart_b
    type: bool
substitutions:
  $esphome_name: "wgtgrdr1"
  $tagreader_name: "WGTagreader1"
esphome:
  platform: ESP32
  board: esp-wrover-kit
  on_boot:
    - priority: 600
      then:
        - script.execute: online_light_set
        - light.turn_on:
            effect: blink_very_fast
        - light.turn_on:
            effect: strobe_unknown_state
    - priority: -100.0
      then:
        - delay: 5s
        - wait_until:
            api.connected
        - lambda: |-
            id(api_was_connected) = 1;
        - light.turn_off:
        - script.execute: set_buzzer_busy
        - script.execute: beep_short_twice
        - delay: 200ms
        - output.turn_off: buzzer_output
        - delay: 2000ms
        - script.execute: set_buzzer_not_busy
        - homeassistant.service:
            service: script.${esphome_name}_init
            data: {}
        - lambda: ESP_LOGD("TEST", "boot finished");
        - lambda: id(raw_value).publish_state("");
        - binary_sensor.template.publish:
            state: !lambda 'return id(heart_b);'
ethernet:
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO0_IN
  phy_addr: 1
  power_pin: GPIO16
logger:
  #level: DEBUG
  level: INFO
api:
  password: !secret api_password
  services:
    - service: hass_init_executed_set
      then:
        - lambda: |-
            id(hass_init_executed_state) = true;
            state: ON
    - service: beep_short
      then:
    - service: beep_short_twice
      then:
    - service: beep_dee_dah
      then:
        - script.execute: beep_dee_dah
    - service: beep_dah_dee
      then:
        - script.execute: beep_dah_dee
    - service: external_buzzer_off
      then:
        - script.execute: script_external_buzzer_off
    - service: external_buzzer_beep_fast
      then:
        - script.execute: script_external_buzzer_beep_fast
    - service: external_buzzer_beep_very_fast
      then:
        - script.execute: script_external_buzzer_beep_very_fast
    - service: external_buzzer_beep_slow
      then:
        - script.execute: script_external_buzzer_beep_slow
    - service: external_buzzer_beep_very_slow
      then:
        - script.execute: script_external_buzzer_beep_very_slow
ota:
  password: !secret ota_password
script: !include scripts.yaml
wiegand:
  - id: reader
    d0: 36
    d1: 39
    on_raw:
      - script.execute: raw_value_wipe
      - lambda: |-
          std::string val =  str_sprintf("(%dbits) %x",bits,value);
          id(raw_value).publish_state(val);
    on_tag:
      - if:
          condition:
            lambda: 'return id(tag_ena) == true;'
          then:
            - if:
                condition:
                  lambda: 'return id(kHz125) == true;'
                then:
                  - homeassistant.tag_scanned: !lambda |-
                      char buf[128];
                      sprintf(buf, "%s", x.c_str());
                      std::string s = buf;
                      std::string s1 = "ID_";
                      s.insert(s.begin(), 10 - s.size(), '0');
                      s1+=s;
                      return s1;
                  - lambda: ESP_LOGD("TEST", "received tag %s", x.c_str());
                else:
                      char buf[128];
                      std::string s1 = "IC_";
                      s1+=s;
                      return s1;
          else:
            - script.execute: beep_short_four_times
button:
  - platform: restart
    name: "${tagreader_name} Restart button"
switch:
  - platform: restart
    internal: true
    name: "${tagreader_name} 125 kHz"
    restore_mode: RESTORE_DEFAULT_OFF
    turn_on_action:
      - lambda: |-
          id(kHz125) = true;
    turn_off_action:
      - lambda: |-
          id(kHz125) = false;
    lambda: return id(kHz125);
    name: "${tagreader_name} Tag Enable"
    restore_mode: RESTORE_DEFAULT_ON
    turn_on_action:
      - lambda: |-
          id(tag_ena) = true;
    turn_off_action:
      - lambda: |-
          id(tag_ena) = false;
    lambda: return id(tag_ena);
    name: "${tagreader_name} Sound Enable"
    lambda: |-
      lambda: return id(sound_ena);
    turn_on_action:
      - lambda: |-
          id(sound_ena) = true;
    turn_off_action:
      - lambda: |-
          id(sound_ena) = false;
output:
  - id: led_output
    platform: gpio
    inverted: true
    pin: 4
  - id: buzzer_output
    platform: gpio
    inverted: true
    pin:
      number: 2
  - id: online_led_output
    platform: gpio
    inverted: false
    pin: GPIO14
  - id: external_buzzer_output
    platform: gpio
    inverted: false
    pin: GPIO15
light:
  - platform: binary
    output: led_output
    effects: !include light_effects.yaml
  - platform: binary
    name: "${tagreader_name} Online LED"
    output: online_led_output
    restore_mode: ALWAYS_OFF
  - platform: neopixelbus
    variant: APA106
    pin: GPIO12
    num_leds: 1
    default_transition_length: 10ms
    flash_transition_length: 10ms
    method:
      type: esp32_rmt
      channel: 0
    type: RGB
    name: "${tagreader_name} Status LED"
    effects: !include rgb_light_effects.yaml
  - platform: binary
    name: "${tagreader_name} External Buzzer"
    internal: true
    output: external_buzzer_output
    effects: !include buzzer_effects.yaml
binary_sensor:
  - platform: status
    name: "${tagreader_name} Buzzer busy"
    name: "${tagreader_name} Hass init executed"
    publish_initial_state: true
    lambda: return id(hass_init_executed_state);
  - platform: gpio
    pin:
      number: GPIO35
      inverted: true
    name: "${tagreader_name} Online status"
    internal: true
    on_state:
      then:
    name: "${tagreader_name} Heartbeat"
text_sensor:
  - platform: version
    name: "${tagreader_name} ESPHome Version"
  - name: "${tagreader_name} Raw value"
    platform: template
    icon: mdi:raw
    #lambda: |-
    #  return {""};
    #update_interval: 60s
  - platform: ethernet_info
    ip_address:
      name: "${tagreader_name} IP address"
  - platform: uptime
    update_interval: 10s
interval:
  - interval: 20sec
    then:
      - if:
          condition:
            api.connected:
          then:
            - lambda: |-
                id(heart_b) = !id(heart_b);
      - if:
          condition:
            lambda: 'return id(api_was_connected) > 0;'
          then:
            - if:
                condition:
                  not:
                    api.connected:
                then:
                  - if:
                      condition:
                        lambda: 'return id(reboot_counter) == 0;'
                      then:
                        - light.turn_on:
                        - light.turn_on:
                  # Reboot after 20 cycles (20 * 20sec = 5min)
                  - if:
                      condition:
                        lambda: 'return id(reboot_counter) > 20;'
                      then:
                        - switch.turn_on: rst_switch
                        - lambda: |-
                            id(reboot_counter) = 0;
                  - lambda: |-
                      id(reboot_counter) += 1;
                else:
                  - if:
                      condition:
                        lambda: 'return id(reboot_counter) > 0;'
                      then:
                        - lambda: |-
                        - light.turn_off:
                        - light.turn_off:
                        - light.turn_on:
                            effect: "None"
                        - light.turn_on:
                            effect: "None"
                        - light.turn_off:
                        - light.turn_off:
                        - delay: 2000ms
                            data: {}
          # Should be impossible to come here, but is not.
          # It looks, firs intervall pass is called right after boot,
          # so it need more time to complete on_boot routines
          # (Learned this in harder way, briked device in endless reboot loop)
          else:
            - if:
                condition:
                then:
                  - light.turn_on:
                  - light.turn_on:
            - if:
                condition:
                then:
                  - lambda: |-
            - lambda: |-
# EOF
Thanks @IgorZg –very helpful code. I was wondering if I need to connect the D0 and D1 output to specific pins… Do they need to be Serial, Analog, Control, etc.? Thanks
Required reading. Probably most GPIOs are ok.
Any regular gpio will work. You gotta check though, a lot of those readers output 5v on their data lines. I tried looking in the data sheet but i didn’t see it mentioned or missed it completely. On mine keypad/rfid reader, it outputs 5v and likewise most of the ones ive seen people in use are 5v.
If you dont actually need an esp32, you can use an esp8266 NodeMCU which will handle 5v just fine or you’ll need to either buy or make a logic level shifter to drop that 5v to 3.3v.
Obviously check it with a multimeter first but, my money is on it being 5v.
I did see this in the data sheet if it helps. This is how you put it in Wiegand26 or Wiegand34 output mode, grounding the blue wire.
Thanks for this, indeed the output is at 5V –should I prefer certain GPIOs given this?
Hi folks –
Here’s my entire code, however I received nothing on the logs:
esphome:
  platform: ESP32
# Enable logging
logger:
  level: DEBUG
api:
  encryption:
    key: "xxxxxxxxxxxxxxxxxxx"
ota:
  - platform: esphome
    password: "xxxxxxxxxxxxxxxxxxx"
wifi:
  ap:
captive_portal:
wiegand:
  - id: reader
    d0: GPIO34
    d1: GPIO35
    on_key:
    on_tag:
    on_raw:
key_collector:
  - id: pincode_reader
    source_id: reader
    min_length: 4
    max_length: 4
    end_keys: "#"
    end_key_required: true
    back_keys: "*"
    clear_keys: "C"
    allowed_keys: "0123456789"
    timeout: 5s
    on_progress:
      - logger.log:
          format: "input progress: '%s', started by '%c'"
          args: [ 'x.c_str()', "(start == 0 ? '~' : start)" ]
    on_result:
      - logger.log:
          format: "input result: '%s', started by '%c', ended by '%c'"
          args: [ 'x.c_str()', "(start == 0 ? '~' : start)", "(end == 0 ? '~' : end)" ]
    on_timeout:
      - logger.log:
          format: "input timeout: '%s', started by '%c'"
The Wiegand reader is at Wiegand26 output with the blue wire connected to the ground.
Any advice? Thank you!
i also have one connected to a WT32-ETH01 board and it works well very simple setup on my end to just get the tag string.
esphome:
  friendly_name: ESPHome Front Door
  platform: ESP32
ethernet:
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO0_IN
  phy_addr: 1
  power_pin: GPIO16
  manual_ip:
    static_ip: xxxxxxxxxx
    gateway: xxxxxxxxxx
    subnet: xxxxxxxxx
# Enable logging
logger:
api:
  encryption:
    key: "xxxxxxxxxxxxxxxxxxxxx"
web_server:
  auth:
    username: !secret web_server_username
    password: !secret web_server_password
  include_internal: true
ota:
  - platform: esphome
wiegand:
  - id: reader
    d0: GPIO4
    d1: GPIO2
    on_tag:
      then:
        - lambda: ESP_LOGD("TAG", "received tag %s", x.c_str());
        - logger.log: "Triggered"
        - homeassistant.tag_scanned: !lambda 'return x;'
        - lambda: |-
            std::string str = esphome::to_string(x);
            id(toggleBit) = true;
            id(tag_id).publish_state(str.c_str());
        - lambda: |-
            id(readerBit) = true;
            id(alarm_reader).publish_state("Scanned");
    on_raw:
globals:
  - id: toggleBit
    type: bool
    initial_value: 'false'
  - id: readerBit
    type: bool
interval:
  - interval: 3000ms
    then:
      - lambda: |-
          if ((!id(toggleBit)) && (id(tag_id).state != "N/A")){
            id(tag_id).publish_state("N/A");
          if(id(toggleBit)){
            id(toggleBit) = false;
  - interval: 3000ms
    then:
      - lambda: |-
          if ((!id(readerBit)) && (id(alarm_reader).state != "Waiting")){
            id(alarm_reader).publish_state("Waiting");
          if(id(readerBit)){
            id(readerBit) = false;
text_sensor:
Thanks, I don’t really understand what I am doing wrong…
Thanks for this @IgorZg –I found the issue, which was NOT grounding the ESP32 GND with the one on the Weigand keypad’s side.
I was wondering if you could also share your scripts, as the code you shared can be very useful to me. Thanks in advance!
Sure I can. This is content of scripts.yaml:
- id: beep_short
    then:
      - if:
          condition:
            lambda: 'return id(sound_ena) == true;'
          then:
            - output.turn_on: buzzer_output
            - output.turn_on: external_buzzer_output
            - delay: 150ms
            - output.turn_off: external_buzzer_output
  - id: beep_short_twice
    then:
      - if:
          condition:
          then:
            - delay: 75ms
            - delay: 150ms
            - delay: 75ms
  - id: beep_short_four_times
    then:
      - if:
          condition:
          then:
            - delay: 75ms
            - delay: 150ms
            - delay: 75ms
            - delay: 150ms
            - delay: 75ms
            - delay: 150ms
            - delay: 75ms
  - id: beep_dah_dee
    then:
      - if:
          condition:
          then:
            - delay: 350ms
            - delay: 100ms
            - delay: 100ms
  - id: beep_dee_dah
    then:
      - if:
          condition:
          then:
            - delay: 100ms
            - delay: 100ms
            - delay: 350ms
  - id: set_buzzer_busy
    then:
           state: ON
  - id: set_buzzer_not_busy
    then:
           state: OFF
  - id: raw_value_wipe
    mode: restart
    then:
      - delay: 60sec
  - id: online_light_set
    then:
      - if:
          condition:
            lambda: 'return id(online_status).state;'
          then:
            - logger.log: "True"
            - light.turn_on: online_led
          else:
            - logger.log: "False"
            - light.turn_off: online_led
  - id: script_external_buzzer_off
    then:
      - light.turn_off: external_buzzer
  - id: script_external_buzzer_beep_fast
    then:
      - light.turn_on:
          effect: beep_fast
  - id: script_external_buzzer_beep_very_fast
    then:
      - light.turn_on:
          effect: beep_very_fast
  - id: script_external_buzzer_beep_slow
    then:
      - light.turn_on:
          effect: beep_slow
  - id: script_external_buzzer_beep_very_slow
    then:
      - light.turn_on:
          effect: beep_very_slow
Also, light_effects.yaml:
- lambda:
          update_interval: 4s
          lambda: |-
            if (id(led_status) == 0) {
              id(led_output).turn_on();
              id(led_status) = 1;
            } else {
              id(led_output).turn_off();
              id(led_status) = 0;
      - lambda:
          update_interval: 1s
          lambda: |-
              id(led_status) = 1;
            } else {
              id(led_status) = 0;
      - lambda:
          update_interval: 100ms
          lambda: |-
              id(led_status) = 1;
            } else {
              id(led_status) = 0;
      - lambda:
          update_interval: 50ms
          lambda: |-
              id(led_status) = 1;
            } else {
              id(led_status) = 0;
      - lambda:
          update_interval: 200ms
          lambda: |-
            // SOS ...---...
            id(led_status) = id(led_status) + 1;
            switch (id(led_status)){
              case 1:
              case 3:
              case 5:
              case 7:
              case 10:
              case 13:
              case 16:
              case 18:
              case 20:
                break;
              case 2:
              case 4:
              case 6:
              case 9:
              case 12:
              case 15:
              case 17:
              case 19:
              case 21:
                break;
              case 8:
              case 11:
              case 14:
              case 22:
              case 23:
              case 24:
              case 25:
              case 26:
                // do nothing
                break;
              default:
                id(led_status) = 0;
                break;
      - lambda:
          update_interval: 250ms
          lambda: |-
              case 1:
                break;
              case 2:
                break;
              case 3:
              case 4:
              case 5:
              case 6:
              case 7:
              case 8:
              case 9:
              case 10:
              case 11:
              case 12:
              case 13:
              case 14:
              case 15:
              case 16:
              case 17:
              case 18:
              case 19:
              case 20:
              case 21:
              case 22:
              case 23:
                // do nothing
                break;
              default:
                id(led_status) = 0;
                break;
      - lambda:
          lambda: |-
              case 1:
                break;
              case 2:
                break;
              case 3:
              case 4:
              case 5:
              case 6:
              case 7:
              case 8:
              case 9:
              case 10:
              case 11:
              case 12:
              case 13:
              case 14:
              case 15:
                // do nothing
                break;
              default:
                id(led_status) = 0;
                break;
      - lambda:
          lambda: |-
              case 1:
                break;
              case 2:
                break;
              case 3:
              case 4:
              case 5:
              case 6:
              case 7:
              case 8:
              case 9:
              case 10:
              case 11:
              case 12:
              case 13:
              case 14:
              case 15:
                // do nothing
                break;
              default:
                id(led_status) = 0;
                break;
and rgb_light_effects.yaml:
#   effects:
      - strobe:
          colors:
            - state: True
              brightness: 10%
              red: 0%
              green: 100%
              blue: 0%
              duration: 100ms
            - state: True
              brightness: 20%
              red: 0%
              green: 100%
              blue: 0%
              duration: 100ms
            - state: True
              brightness: 30%
              red: 0%
              green: 100%
              blue: 0%
              duration: 100ms
            - state: True
              brightness: 40%
              red: 0%
              green: 100%
              blue: 0%
              duration: 100ms
            - state: True
              brightness: 50%
              red: 0%
              green: 100%
              blue: 0%
              duration: 100ms
            - state: True
              brightness: 40%
              red: 0%
              green: 100%
              blue: 0%        duration: 100ms
            - state: True
              brightness: 30%
              red: 0%
              green: 100%
              blue: 0%
              duration: 100ms
            - state: True
              brightness: 20%
              red: 0%
              green: 100%
              blue: 0%
              duration: 100ms
            - state: True
              brightness: 10%
              red: 0%
              green: 100%
              blue: 0%
              duration: 100ms
            - state: True
              brightness: 0%
              red: 0%
              green: 100%
              blue: 0%
              #duration: 4s
              duration: 2s
      - strobe:
          colors:
            - state: True
              brightness: 50%
              red: 0%
              green: 100%
              blue: 0%
              duration: 250ms
            - state: True
              brightness: 50%
              red: 100%
              green: 100%
              blue: 0%
              duration: 250ms
      - strobe:
          colors:
            - state: True
              brightness: 50%
              red: 100%
              green: 0%
              blue: 0%
              duration: 500ms
            - state: False
              duration: 4s
      - strobe:
          colors:
            - state: True
              brightness: 30%
              red: 0%
              green: 0%
              blue: 100%
              duration: 100ms
            - state: True
              brightness: 40%
              red: 0%
              green: 0%
              blue: 100%
              duration: 100ms
            - state: True
              brightness: 50%
              red: 0%
              green: 0%
              blue: 100%
              duration: 100ms
            - state: True
              brightness: 60%
              red: 0%
              green: 0%
              blue: 100%
              duration: 100ms
            - state: True
              brightness: 50%
              red: 0%
              green: 0%
              blue: 100%
              duration: 100ms
            - state: True
              brightness: 40%
              red: 0%
              green: 0%
              blue: 100%
              duration: 100ms
            - state: True
              brightness: 30%
              red: 0%
              green: 0%
              blue: 100%
              duration: 2s
      - strobe:
          colors:
            - state: True
              brightness: 50%
              red: 100%
              green: 0%
              blue: 0%
              duration: 250ms
            - state: True
              brightness: 50%
              red: 0%
              green: 100%
              blue: 0%
              duration: 250ms
      - strobe:
          colors:
            - state: True
              brightness: 50%
              red: 100%
              green: 0%
              blue: 0%
              duration: 250ms
            - state: True
              brightness: 50%
              red: 0%
              green: 0%
              blue: 100%
              duration: 250ms
      - strobe:
          colors:
            - state: True
              brightness: 20%
              red: 100%
              green: 80%
              blue: 0%
              duration: 100ms
            - state: False
              duration: 100ms
      - strobe:
          colors:
            - state: True
              brightness: 38%
              red: 0%
              green: 0%
              blue: 38%
              duration: 100ms
            - state: False
              duration: 100ms
      - strobe:
          colors:
            - state: True
              brightness: 38%
              red: 100%
              green: 0%
              blue: 0%
              duration: 100ms
            - state: False
              duration: 500ms
            - state: True
              brightness: 38%
              red: 0%
              green: 100%
              blue: 0%
              duration: 100ms
            - state: False
              duration: 500ms
            - state: True
              brightness: 38%
              red: 0%
              green: 0%
              blue: 100%
              duration: 100ms
            - state: False
              duration: 500ms
Best regards!
Here’s mine if it helps. Unlike the other example posted, I don’t send the Pin codes or Tag’s scanned to HA so they can be checked or whatever is done with them. I read the Pin/Tag on the Esp, compare it against known user’s pin/tag and everything is processed on the board first and then second sent to HA.
################ Guest Mode Timers  #############
# Use both Start and Stop timers to specify which times of the day are allowed for the guest.
# Example: Start Time 08:00:00Am - Stop Time 05:00:00Pm Will Only Allow Access between Those Times (9 Hours)
datetime:
   type: time
   name: "Guest Mode Time On"
   optimistic: yes
   initial_value: "08:00:00"
   restore_value: true
   on_time:
     - if:
        condition:
          - switch.is_on: guest_active
        then:
          - switch.turn_on: guest_active
   type: time
   name: "Guest Mode Time Off"
   optimistic: yes
   initial_value: "05:00:00"
   restore_value: true
   on_time:
     - if:
        condition:
          and:
            - text_sensor.state:
                state: open
        then:
          - button.press: transmit_rf
        else:
          - switch.turn_off: guest_active
number:
    name: "Set New Code"
    min_value: 0
    max_value: 9999
    step: 1
    mode: box
    optimistic: true
    on_value:
      if:
        condition:
        then:
          - globals.set:
              value: !lambda 'return x;'
sun:
   latitude: 40.173568
   longitude: -86.0225536
   on_sunset:
    - light.turn_on:
        brightness: 50%
        white: 100%
    - switch.turn_on:
   on_sunrise:
    - light.turn_off:
    - switch.turn_off:
time:
  - platform: homeassistant
remote_transmitter:
  pin: 4
  carrier_duty_percent: 100%
###########  Send Test Code + "#" key  to Keypad  #######
button:
    name: "test send number"
    on_press:
      then:
        - lambda: |-
            id(pincode_reader).send_key('1');
        - delay: 250ms
        - lambda: |-
            id(pincode_reader).send_key('2');
        - delay: 250ms
        - lambda: |-
            id(pincode_reader).send_key('3');
        - delay: 250ms
        - lambda: |-
            id(pincode_reader).send_key('4');
        - delay: 50ms
        - lambda: |-
            id(pincode_reader).send_key('#');
    name: "Overhead Door RF"
    on_press:
      then:
        - remote_transmitter.transmit_rc_switch_raw:
            code: '00101001100111110101101'          ####  Test Code Only  '00100100100001'  #######
            protocol: 1
            repeat:
              times: 1
              wait_time: 0ms
  - platform: restart
  - platform: safe_mode
    name: "Keypad (Safe Mode)"
switch:
    optimistic: true
###############  Enable/Disable Guest Mode for use with Keypad  #######
    optimistic: True
    restore_mode: DISABLED
    on_turn_off:
      then:
        - number.set:
            value: 0
    optimistic: true
    on_turn_on:
          service: switch.toggle
           entity_id: switch.overhead_door_rf_barn_overhead_door
  - platform: gpio
    pin:
      number: 25
    #mode:
      inverted: true
    name: 'Barn Door Lights'
    #optimistic: true
  - platform: gpio
    name: "Barn Switch 1"
    pin:
      number: 15
      inverted: false
    device_class: switch
  - platform: gpio
    name: "Barn Switch 2"
    pin:
      number: 5
      inverted: false
    optimistic: true
    turn_on_action:
       - switch.turn_on: barn_switch1
       - switch.turn_on: barn_switch2
    turn_off_action:
       - switch.turn_off: barn_switch1
       - switch.turn_off: barn_switch2
binary_sensor:
  - platform: gpio
    name: "Small Barn Door"
    pin:
      number: 12
      mode:
        input: true
        pullup: true
      inverted: true
    device_class: door
#  - platform: gpio
#    name: "Light Switch1"
#    id: barn_switch_sensor1
#    pin:
#      number: 23
#      mode:
#        input: true
#        pullup: true
#      inverted: False
#    filters:
#      - settle: 1.5s
#      - delayed_on_off: 1.5s
#    on_state:
#      - if:
#          condition:
#            - switch.is_off:
#                id: barn_switch1
#          then:
#            - switch.turn_on:
#                id: barn_switch1
#          else:
#            - switch.turn_off: barn_switch1
          #      - switch.template.publish:
          #          id: barn_inside_lights
          #          state: OFF
  - platform: gpio
    pin:
      number: 14
      mode:
        input: true
        pullup: true
      inverted: true
    filters:
      - settle: 1.5s
    on_state:
      then:
        - switch.toggle: barn_switch1
        - switch.toggle: barn_switch2
  - platform: status
    name: Barn Keypad Status
text_sensor:
  - platform: sun
    type: sunrise
  - platform: sun
    type: sunset
    update_interval: 5s
    lambda: return  id(homeassistant_time).utcnow();             # .now();           #######  .now().strftime("%I%M%p");  #######
    entity_id: cover.overhead_door_rf_overhead
    internal: false
    icon: mdi:clock-start
  - platform: wifi_info
    ip_address:
      name: Keypad IP Address
    ssid:
      name: Keypad Connected SSID
   # mac_address:
    #  name: Keypad Mac Address
    scan_results:
      name: Keypad Latest Scan Results
    dns_address:
    name: "Door Access Method"
    icon: mdi:account-multiple
globals:
  - id: method
    type: std::string
    restore_value: yes
    max_restore_data_length: 13
    initial_value: ""
  # Example for global string variable
  - id: last_user_access
    type: std::string
    restore_value: yes
    initial_value: ""
  - id: temp_code
    type: int
    restore_value: yes
    max_restore_data_length: 4
    initial_value: ""
  - platform: duty_time
    name: "Door Open Time"
    # Support logical sources (optional): 'binary_sensor'
    sensor: barn_door_small
    restore: true                                      # Sensor for last turn-on time (optional)
    last_time:
      name: "Last Time Door Open"
    on_value:
      - if:
         condition:
           - lambda: 'return id(keyCode).state == 1050;'
         then:
           - lambda: |-
                  id(ovrhead).toggle();
                  id(last_user).publish_state("Justin");
                  id(door_access_method ).publish_state("Pin Code");
      - if:
          condition:
              - lambda: 'return id(keyCode).state != 1050;'
              - lambda: 'return id(keyCode).state != 1955;'
              - lambda: 'return id(keyCode).state != 6800;'
              - lambda: 'return id(keyCode).state != 2014;'
              - lambda: 'return id(keyCode).state != id(temp_code);'
          then:
             - text_sensor.template.publish:
                state: "Invalid Code"
      - if:
          condition:
            - lambda: 'return id(keyCode).state == 6800;'
          then:
            - lambda: |-
                  id(last_user).publish_state("Paula");
      - if:
          condition:
            - lambda: 'return id(keyCode).state == 1955;'
          then:
             - lambda: |-
                  id(last_user).publish_state("Mike");
      - if:
          condition:
            - lambda: 'return id(keyCode).state == 2014;'
          then:
             - lambda: |-
                  id(last_user).publish_state("Olive");
      - if:
          condition:
            and:
              - lambda: 'return id(keyCode).state == id(temp_code);'
          then:
            - logger.log: "KeyCode equals temp code!"
               state: "Temp. Code"
           #  - lambda: |-
            #     if (x == "6789"); {
             #     id(ovrhead).toggle();
              #    id(last_user).publish_state("Temp. Code");
                 # id(last_user_access) = "Temp Code";
      - if:
          condition:
            and:
             # - alarm_control_panel.is_armed: acp1
              - lambda: 'return id(keyCode).state == 6753957;'
          then:
           # - alarm_control_panel.disarm:
            #    id: acp1
             #   code: "2014"
            - delay: 1s
            - switch.toggle: ovrhead
                state: "Justin Tag"
                state: "Disarmed By Justin"
          else:
         #   if:
          #    condition:
           #     not:
             # then:
                if:
                  condition:
                  then:
                     - lambda: |-
                              id(door_access_method).publish_state("RFID Tag");
      - if:
            condition:
            - lambda: 'return id(keyCode).state == 6422842;'
            then:
                     - lambda: |-
                              id(door_access_method ).publish_state("RFID Tag");
      - if:
          condition:
            - lambda: 'return id(keyCode).state == 6491970;'
          then:
                     - lambda: |-
      - if:
          condition:
            - lambda: 'return id(keyCode).state == 5553549;'
          then:
                     - lambda: |-
                               id(last_user).publish_state("Golf Cart Key1");
      - if:
          condition:
            - lambda: 'return id(keyCode).state == 5627758;'
          then:
                     - lambda: |-
                               id(last_user).publish_state("Golf Cart Key2");
  - platform: wifi_signal
    update_interval: 300s
    entity_category: "diagnostic"
    internal: true
  - platform: copy
    source_id: wifi_signal_db
    name: "WiFi Signal Keypad"
    filters:
      - lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
    unit_of_measurement: "Signal %"
  - platform: uptime #Uptime in Seconds
    name: Barn Keypad Uptime
    update_interval: 240s
    internal: True
    on_raw_value:
      then:
            state: !lambda |-
              int seconds = round(id(uptime_sensor_wiegand).raw_state);
              int days = seconds / (24 * 3600);
              seconds = seconds % (24 * 3600);
              int hours = seconds / 3600;
              seconds = seconds % 3600;
              int minutes = seconds /  60;
              seconds = seconds % 60;
              return (
                (days ? String(days) + "d " : "") +
                (hours ? String(hours) + "h " : "") +
                (minutes ? String(minutes) + "m " : "") +
                (String(seconds) + "s")
              ).c_str();
wiegand:
  - id: mykeypad
    d0: 21 ## Grn
    d1: 19 ## Wht
    on_key:
    on_tag:
      - sensor.template.publish:
         state: !lambda "return parse_number<float>(x).value();"
      - if:
          condition:
            and:
              - lambda: 'return id(keyCode).state != 5553549;'
              - lambda: 'return id(keyCode).state != 6422842;'
              - lambda: 'return id(keyCode).state != 6491970;'
              - lambda: 'return id(keyCode).state != 6753957;'
   #          - lambda: 'return id(keyCode).state != #######;'
          then:
                state: "Invalid Tag Scanned"
    on_raw:
key_collector:
    source_id: mykeypad
    min_length: 4
    max_length: 5
    end_keys: "#"
    clear_keys: "*"
    timeout: 5s
    on_progress:
      - logger.log:
    on_result:
      then:
    on_timeout:
      - logger.log:
# D1
light:
    type: RGB
    variant: WS2811
    pin: 17
    num_leds: 20
    name: "Barn Door LED Strip"
select:
    name: "Barn Light Effect"
    options:
      - "R/W/B"
      - "B/R/W"
    initial_option: ""
    optimistic: True
    on_value:
      then:
        if:
          condition:
            - lambda: 'return id(barn_led_effect).state == "R/W/B";'
          then:
            - light.addressable_set:
                range_from: 0
                range_to: 7
                red: 100%
                green: 0%
                blue: 0%
                color_brightness: 100%
                range_from: 8
                range_to: 14
                red: 0%
                green: 0%
                blue: 0%
                white: 100%
                range_from: 15
                range_to: 20
                red: 0%
                green: 0%
                blue: 100%
interval:
 - interval: 1min
   then:
     - if:
         condition:
           and:
             - sun.is_below_horizon:
             - light.is_off:
         then:
           - light.turn_on:
               brightness: 75%
               red: 0%
               green: 0%
               blue: 100%
     - if:
         condition:
           and:
             - sun.is_above_horizon:
             - light.is_on:
         then:
           - light.turn_off:
     - if:
         condition:
           and:
             - switch.is_on:
         then:
           - switch.turn_off:
