Hi all,
I have a networking issue with HASSio 5.9. I managed to set it up on a RPi4 and even download add-ons on a wifi network which is connected to the internet (router A). However I’d like to have an other network for my smart home devices (router B) without internet, to wich I’d like to connect via ethernet. When the ethernet is not plugged in, everyting works fine, and hassio ha network info
says the wlan0
is my primary.
Ot he other hand, when ethernet is plugged in (router B), that one becomes the primary network, and I couldn’t find a way to change that (nor in HASS cli not in the UI). A similar question has been raised here: Bridge network connections but remained unanswered.
I even tried importing netwrok settings from USB (with succes according to both cli and ui) where I specified nmcli-style never-default: true
, but that didn’t helped either.
Is it achievable with HASSio, or should I try a docker-based solution where I can manage the host’s network?
